Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #11 (permalink)
Old 05-22-2008
JohnRPollard's Avatar
Moderator
Originally Posted by vabuckeye View Post
I was going to try with a leader long enough to clear the railings and see how I faired.
That's more or less the idea. A tack line from the stem fitting (where the headstay attaches at the bow) to the tack of the sail would be fine, allowing the foot of the sail to clear the bow pulpit. Better still if you could lead that same line back to the cockpit (through a turning block at the bow), so you could adjust the luff tension easily.
  #12 (permalink)
Old 05-22-2008
vabuckeye's Avatar
vabuckeye will become famous soon enough vabuckeye will become famous soon enough
Thanks. I have the blocks. Just need to purchase the line.
Jim
  #13 (permalink)
Old 05-22-2008
Vabuckeye-
If you want leverage, put a purchase on the line.
  #14 (permalink)
Old 05-23-2008
vabuckeye's Avatar
The lazy sheet will just lay across the deck I assume. As I perform a text book gibe, because the tack is above the railings, as the sail comes about, under perfect conditions, with a top notch crew, the lazy sheet will pick up off the deck, not get tangled in any other lines, become the active sheet, while the active sheet comes across the bow, clears the railings, will lay perfectly across the deck to become the lazy sheet.
As all this is going on the spinnaker will stay full of wind, no one goes overboard, and you can hear the cheering from the other boats with the hint of jealousy.
Piece of cake.
Have I missed anything?
This seems like a Kodak moment.
Jim
  #15 (permalink)
Old 05-23-2008
You missed where the spinnaker wraps around the forestay cause the skipper turned the boat too fast... and the boat gets knocked down due to the spinnaker wrap.
Piece of cake.
Jim
Refining Your Downwind Sails Brian Hancock Gear and Maintenance Articles 0 04-06-2004 08:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
