Stepping the mast - Page 2 - SailNet Community
post #11 of 16 Old 08-15-2008
Rich-
just don't wear your stiletto heels on the foredeck.
Originally Posted by RichNH View Post
Hey thanks guys, Some great ideas, I think the winch one will work great. I appreciate it and will try to try something this weekend. Pics to follow hopefully without blood... :-)
I'm making an assumption that the deck can take my weight (200lbs). It is covered with a gray mat of some type that looks like its meant to be walked on. I have to assume that it's designed for that since to change sails at the forestay while under sail you'd have to walk on it in order to do the job.
I am getting VERY excited, only a few hours to go before the weekend arrives.... YEA!
Rich
sailingdog is offline
post #12 of 16 Old 08-15-2008 Thread Starter
RichNH's Avatar
Yeah! Or my crampons either! LOL
After I got home I was checking the mast and where it mounts closely (before the thunderstorm moved in). I noticed that the back stay has an extra 2' cable spliced to it about 5' above where the stay hooks on the boat. The end of this extra cable has a small snap hook on it. May I presume that this is to support the end of the boom (the only purpose I can imagine) when the mainsail isn't raised?
RichNH is offline
post #13 of 16 Old 08-15-2008
Ok, now I'm worried...you've got a pair of stiletto heels???
post #14 of 16 Old 08-15-2008 Thread Starter
RichNH's Avatar
Lololololol
RichNH is offline
post #15 of 16 Old 08-17-2008
Once known as Hartley18
Classic30's Avatar
Dock
Rich, that's correct.
From what you've posted, it sounds like the boat is meant to be rigged by simply picking the mast up and dropping it in the hole (don't drop it too hard!), then fixing the stays and sails. Others classes rigged like this include the Laser and OK Dinghy.
Some 16-footers have an adjustable forestay leading back to the cockpit which can be connected first to provide some support, but basically, start with the stays wrapped around the mast, pick it up and drop it in... or ask someone else to do it for you!
Cameron
Classic30 is offline
post #16 of 16 Old 08-19-2008 Thread Starter
RichNH's Avatar
Thanks Cameron, I appreciate the feedback.
16' daysailer
Southern NH
RichNH is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-01-2016 11:48 PM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
Small Boat Mast Stepping SailNet Gear and Maintenance Articles 0 06-12-2002 08:00 PM
