08-15-2008
Obviously with a keel stepped mast one cannot attach shrouds and forestay before raising. Perhaps you could use a couple lines somewhat longer than the shrouds, or even rig a couple long 2x4's with a collar around the mast, which will keep it from falling sideways. A crane, a gin pole, or even a bridge works best, lifting the spar with a pulley overhead, lowering it straight down the deck opening, attaching the shrouds before letting the overhead lifting line loose!
Don To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
