Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 08-17-2008
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
Can you sail with limited heel?
Is it possible to sail with limited heel? I was sailing today in my catalina 27 there was a catalina 34 we were following. The 34 was going slightly faster than us but we were heeling a lot more while the 34 was not heeling that much at all. Is it because that the 34 has a larger and heavier keel and also the beam is bigger? What can I do with my sails to reduce the heel. We were both sailing with the jib and the mainsail. Thanks in advance.
Old 08-17-2008
hphoen's Avatar
"Nevis Nice"
hphoen is on a distinguished road
The rule is...less sail, less heel. Put a reef in the main and hank on a smaller foresail (or roll in the furler if that's what you have.) My boat sails best at 15 degrees heel, so I adjust the sails to achieve that, and it really does make a difference.
Hud
s/y The Belle of Virginia
Island Packet 380 (now sold)
Nevis, West Indies
Old 08-17-2008
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
You don't say what point of sail you were on but if close hauled try moving the traveler to leeward and tighten the foot of the sail using the outhaul. Tighten the halyards as well
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 08-17-2008
saurav16's Avatar
Well the wind was changing a lot it was between a beam reach and close haul.
Old 08-17-2008
Yes, you can sail with limited heel... get a multihull.
If you're on a leadmine... many of the newer designs are going to be faster if they're sailing relatively flat. Reefing and using the sail controls to flatten the sails—outhaul, cunningham, boomvang, backstay tensioner, etc.—will help keep the boat sailing relatively flat and often faster than when the boat is heeled over 25˚+. Most monohulls start to develop serious helm issues when heeled excessively due to the profile of the boat's hull as it heels. Having the rudder over more than a few degrees due to the helm issues is going to act as a brake and really slow the boat down quite a bit as well.
Old 08-17-2008
saurav16's Avatar
Ok well all the adjustments outhaul, boom vang and so on are adjustments for the Main. What kind of adjustments can you do to dump wind from the jib? I assume the jib cars, in heavy wind u want to adjust the jib cars back towards the cockpit to dump wind and flatten sails? Is that right?
Old 08-18-2008
arbarnhart's Avatar
arbarnhart is on a distinguished road
On my little boat, the traveler position makes a big difference.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
Old 08-18-2008
kai34 is on a distinguished road
Sail choice is very important. I would say if you had to start dumping wind and are thinking about messing up the sail shape by flattening it out, its time for a sail change. downsize.
-kai
Old 08-18-2008
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Don't forget more watewline can equate to more speed also.
Old 08-18-2008
Rickm505's Avatar
Rickm505 is on a distinguished road
Precisely My thought as well.
Trimming Your Asymmetrical Spinnaker sandygoodall Seamanship Articles 14 03-31-2010 09:27 AM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Traveler usage? Humpwalker Seamanship 22 02-17-2007 10:54 AM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 07:00 PM
First Sail of the Season Bruce Caldwell Gear and Maintenance Articles 0 06-05-2003 08:00 PM
