Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 07-29-2002
DirkJ is on a distinguished road
Headsail furling: Best practise
Hi folks,
simple question (hopefully): What is the best practise to furl a furling headsail in an out (or reef it)? Go into the wind? Close hauled? Hold the sheet tight with tension or let it loose?
Dirk
Old 07-29-2002
hamiam is on a distinguished road
Personally I like to hold the sheet tight at all times as it gives a tighter wrap. Depends on your system but I can furl and unfurl my Profurl system at any angle.
Old 07-29-2002
Jeff_H's Avatar
Super Moderator
The only other suggestion is to release the halyard and backstay tension a little before furling the sail so as to reduce creep in the luff of the sail and to retension the sail when it is deployed.
Old 07-29-2002
EscapeArtist is on a distinguished road
You should unfurl the headsail after you''ve raised the main and are sailing.
Put the sheet on a winch and start pulling out the sail. Once you get it out a bit, the wind will do the rest.
The important thing to remember is to keep the furling line under a bit of tension as the sail unfurls. As the sail unfurls, the furling line is wrapping onto the furler drum. If you just let the sail fly out with the furling line slack, you''ll get riding turns on the drum and you won''t be able to roll it back up.
In-mast furler; to buy or not to buy; GreggRuch Boat Review and Purchase Forum 55 04-25-2011 06:40 AM
Mechanical difference between roller furling and reefing? duffer1960 Gear & Maintenance 6 10-26-2009 09:46 AM
Roller furling use Sea Gypsy Gear & Maintenance 2 07-14-2003 08:09 AM
Roller Furling on a trailered boat? cantwisle Gear & Maintenance 4 03-19-2002 11:57 AM
Hood in mast furling JohnYates Gear & Maintenance 6 05-05-2001 12:14 PM
