Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 09-04-2002
cyrusallen is on a distinguished road
Lazy Jack - how to use?
Hi, I haven''t used a lazy jack system before - would like to know key tips for raising and lowering the main, as well as sail handling underway. Thanks!
Old 09-23-2002
HHJ HHJ is offline
HHJ is on a distinguished road
The only issue I''m aware of is raising the main. If you have battens, be careful the top one or two don''t get caught in the lazy jack''s lines on the way up.
Mine are elastic and easily removed from the boom and stowed on the mast. I leave them in the stowed position until the main is raised, then deploy them so that they''re ready for arrival. That''s when they really prove their worth - making sailhandling in flaking the main much easier.
I''ve had no issues at all while sailing.
Old 09-23-2002
WHOOSH is on a distinguished road
I''d suggest folks take a look at the illustration and short discussion on this in Beth Leonard''s cruising handbook. Using the spreaders vs. the mast as the attachment point and the removeable nature of their arrangement makes good enough sense to me that I''m going to use this system. I think HHJ is on target when he points out they only serve a purpose when dropping the main (and perhaps mizzen, altho'' in sun country that usually falls on top of the bimini).
Jack
Old 09-23-2002
Jeff_H's Avatar
Super Moderator
Mounting lazy jacks on the spreaders is a really bad idea as it can put a lot of impact loading on the spreaders as the boom swings in a seaway. Eventually this will take a very serious toll and could bring down the rig.
Old 09-24-2002
...but only if they are left rigged in place. Lazy jacks are for dropping a sail in a seaway, not to serve as permanent running rigging. Again, note Beth Leonard''s description of their use on her & Evans'' circumnavigation.
Jack
Jack Martin Insurance HAH! Any other ideas? VIEXILE Boat Review and Purchase Forum 5 01-15-2002 05:27 AM
Lazy Jacks?? maureena5 Gear & Maintenance 12 11-15-2001 10:29 AM
Ted Herman Lazy Jack duffer1960 General Discussion (sailing related) 0 11-02-2001 07:45 AM
Ted Herman Lazy Jack duffer1960 Boat Review and Purchase Forum 0 11-02-2001 07:44 AM
Lazy Jack System Comparison sehopkins Gear & Maintenance 6 06-07-2001 08:02 PM
