Adding jib sail - SailNet Community
post #1 of 6 Old 09-20-2002 Thread Starter
Adding jib sail
Hi! I became the owner of a 1983 Freedom 21 last year that came with a spinnaker, but I want to add a jib sail. This boat has a carbon-fiber mast, is it possible to rig it to handle a jib? I want to participate in local races and think the jib would certainly add some speed. Thanks!
mikeact41 is offline
post #2 of 6 Old 09-20-2002
Moderator
Jeff_H's Avatar
Adding jib sail
It would probably subtract more from your rating than it would add in speed. You probably could add a jib but you would also probably need to add running backstays as well if it was going to do you much good.
Jeff_H is offline
post #3 of 6 Old 09-20-2002
Senior Moment
SailorMitch's Avatar
Adding jib sail
I suggest posting this question on the Freedom email list here on Sailnet. You''ll get a lot better information from F-21 owners in that forum. You also may want to check with Freedom Yachts. While the carbon fiber masts are tough, they do fail, and when they do, replacing them is not cheap.
SailorMitch is offline
post #4 of 6 Old 08-16-2008
I know that this post is a little late, but here goes. they did design one for the f-21. If you google Freedom21info you can find a file with the correct class approved sailmaker instructions for the jib.
Hank
wbrakman is offline
post #5 of 6 Old 08-16-2008
Forgot to mention that there is also a Yahoo group just for the F21. Lots of good info there also.
Hank
wbrakman is offline
post #6 of 6 Old 08-16-2008
wbrakman-
If he hasn't added a jib by now, he probably won't. The posts you're replying to are SIX YEARS OLD. Please check the dates before replying to a post. Also, highly recommend you read the post in my signature.
sailingdog is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 08:30 AM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 01:19 AM
Traveler usage? Humpwalker Seamanship & Navigation 22 02-17-2007 10:54 AM
