Why reef at all...? - Page 5 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #41 (permalink)
Old 03-15-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Reefer Madness
Now, I'm all for reefer madness.
I love it! Now SmackDaddy says he is all for reefer madness. I had my suspicions before this point (takes one to know one). Reefing is just part of life.
I shared and experience with several of the SN crowd here on Bene505's boat where we put in the first reef and reefed in the fore sail. As the wind built up to nearly 40 kt. gusts we put in the second reef and it was really difficult to furl in the fore/head sail but we did. At this point we found that due to the waves we were making only about 3 knots headway with just the main up so we engaged the engine at a near idle speed and the extra forward momentum helped to get us going at a much more comfortably in about 4 - 5' seas. If we traveled slower we would rock that much more and lose forward progress because of it without the engine pushing as well. This was on a 50' sailboat on LI Sound.
The next day there were 50 kt. peak gusts with an average in the high 30's and we opted for no sails as the waves were a trifle bigger and the wind had shifted to the opposite direction we wanted to go (head winds). Even a smallish body of water can get mad with a lot of wind and real sailors reef and/or start their engines if they want to get home and out of the wrath of the weather. There were 5' rollers avg. out on the water that day which even made a 50' mono hull a bit uncomfortable.
Reefing is smart; splitting your sails is amateur hour.
Reefer is another thing entirely.
  #42 (permalink)
Old 03-15-2009
captainmurph is on a distinguished road
Originally Posted by backcreeksailor View Post
When presumably you could just let the main out to dump a little more air if you're heading upwind, or bring it in to catch less air if you're going down wind. And just avoid the entire evolution of reefing altogether?
Lots of reasons including a balanced helm and the fact that sheeting out or flattening might still result in being seriously overpowered.
A few days after my last BVI trip, three Brits who were "supposedly" experienced sailors put a Beneteau 39 on its size and it subsequently sank - mostly because they were sailing in 35K and gusty with the boom swung out as far as the mainsheet would allow - and then, seemingly out of nowhere, had a microburst that piped the wind to over 55K with no warning.
They put a 250K +, new boat in 90 feet of water - mostly because they had too much sail and no margin for forgiveness when the strong breeze piped up more. If they had not compounded the situation with open hatches, they may not have sunk. They still would have been knocked down!
Many times, you can compensate by heading up as flat as possible or spilling as much as you can by sheeting out. Sometimes, too much sail simply results in the effects of too much sail.
Keep in mind that the sea is very unforgiving of incapacity, carelessness or neglect.
The short answer to your question: Because sometimes that simply isn't enough and less sail is the only answer.
  #43 (permalink)
Old 03-15-2009
lastconch's Avatar
lastconch is on a distinguished road
If you stress more over putting in a reef than damaging yourself or the boats, not to mention racking the nerves. PRACTICE reefing until it becomes easy, and do it before it's to late. Heave to with a partial jib back winded, and the wheel hard over, this makes reefing easier.
Life's an adventure you just gotta live it!
  #44 (permalink)
Old 03-16-2009
jackdale's Avatar
jackdale will become famous soon enough
If you ever ask the question' "Should I reef?", the answer is "yes." Reducing sail area, thus heel angle and rudder angle will probably cause you to go faster.
Jack
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
  #45 (permalink)
Old 03-16-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
Yes; if your windspeeds are up in the 30kt range, it's probably time to get your sails reefed; or end up with damaged sails. This is the point where flattening the sails and spilling or pinching (pointing higher to the wind) either becomes difficult or dangerous if you are rounded into an auto-tack or a wind shift comes and adds more pressure to sheeted in sails.
I don't disagree with your decision to go under motor alone; but some sailboats may not have the power to push ahead into driving waves and wind. So in certain situations having a small amount of sail area like a reefed jib (or storm) and the main at the 3'rd reef or a storm tri can actually be safer than going under motor alone.
Something does not make sense with this. While I understand that a 50kt gust would certainly be enough wind to knock a boat onto it's side; I can't see why it should sink so easily. It really should not happen; but as you said since the ports were open and water gets in the boat may not right itself. To me it sounds like the boat was sailing downwind and 30kts -seemed- safe/controlable and then the boat was rounded up and broached when the 50kt gust hit. If they had the sheets fully eased and were either abeam to the seas/wind or facing upwind there is not much way that the boat could be rolled unless the gust came with a huge shift of wind direction.
We had a heavy blow like CalebD described about 2 years ago; but it was just me and my GF heading out into predicted (moderate) winds. As we left the marina the wind seemed a bit stronger than I expected so to be safe we tucked the 2'nd reef in. As we headed out I could see some whitecaps coming across the point/breakwater at 90deg to the channel and I figured it was probably 20-25kts (still within reason for a robust daysail). She asked if we should put out the headsail and I said no; let's wait and see what the wind is like. Glad I did because as soon as we exited the channel we were in 40-50kts. The boat was on a broad reach and the main was eased; but our hull speed was 7kts (only the main on 2'nd reef). At that point I decided the wind was in the gale or storm force range and that our day was finished due to safety. We waited impatiently for a tug to go into the harbor channel and then we came about and went back in.
As a result; I never trust NOAA implicitly and I never set the headsail out while exiting our marina during the winter when we get those gales from due north. If we had gone out with the headsail full we certainly would have taken a knockdown or at least had some white knuckles until the sail was furled.
In the last couple of years of sailing my boat I have learned that the headsail has much more effect on easing the heel than reducing mainsail. So we generally reef the headsail first because although it is a 105% and high-cut it is more sail area and adds much more power to the sailplan than the main alone. So we furl the jib down quite a bit and the boat sails balanced and in control with a full mainsail (in winds up to 30-35kts).
  #46 (permalink)
Old 05-26-2009
1994 Catalina 270
Trescool is on a distinguished road
Reefing in 10 knot winds???
This thread has lots of great info and I am always a believer in no question is stupid. This had lead to my greater understanding of many things.
I was out this past weekend in Barnegat Bay in my Catalina 270 with winds of 10 knots. I did not reef but saw at least one or two other sailboats with reefed sails.
Am I to assume they were doing this to keep on a certain heading and have more stability? I know I had a little bit of a problem keeping my heading without and had to do a lot of correction.
Thanks!
  #47 (permalink)
Old 05-26-2009
lbdavis's Avatar
lbdavis is on a distinguished road
Thanks!
It everything to do with the boat, and something to do with the crew.
As you've read, reefing will reduce heel. Some boats require this to happen earlier than others due to a myriad reasons surrounding design. My boat, for instance, must be reefed at around 15kts to keep heeling and weather helm in check. Other boats don't need to tie in a reef to 20 knots, 25 knots or more.
Crew is also a consideration. Sometimes you just don't want the boat to heel. This could cause you to reef early as well.
S/V Gracie
P303
  #48 (permalink)
Old 05-26-2009
hwlovett is on a distinguished road
1) sails are expensive.
2) practice makes reefing not a chore more difficult that tightening the outhaul.
3) your boat will be in control.
  #49 (permalink)
Old 05-26-2009
smackdaddy's Avatar
Winning
Reefing in 10 knots? Are you serious? I said "reefer madness" - not "reefer petrification".
I saw the same thing a week or so ago. Just enough wind to get our C27 moving nicely under full main and a 170. Maybe 8-10 knots. Meeeeeelllllllllooooooowwwwwww.
Then I see some dude slogging it with a reefed main and a patch of headsail. I just had to go by and shout obscenities. Just in my genes.
  #50 (permalink)
Old 05-26-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Laying the rail down is not for everyone. Some have a wonderful time just keeping the mast straight up. It's their boat, and their perogative. I always used a 20 degree steady heel as a notice for reduction of sail. On most boats after 20 degrees you are making a lot of leeway, and stressing the boat for nothing.
On S.F. Bay you start reefing about 11am, and shaking them back out about 6pm on the way home. Home for Frolic was straight downwind from the Golden Gate. Of course that's late spring to early fall sailing. The rest of the year can be anything. You can almost set your watch to the wind during summer......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 08:00 PM
Foot Reef? Variant_530 Gear & Maintenance 1 03-28-2002 07:42 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
