Blogs
Go Back   SailNet Community > General Interest Forums > Learning to Sail
User Name
  #11 (permalink)
Old 04-18-2001
sailin23 sailin23 is offline
sailin23 is on a distinguished road
Help! Where to start???
Michael-DEFINATELY AN OUTBOARD! inboards are fine, but it is SO much easier to fix an outboard, or find out what''s wrong with it, or whatever. If it''s your first boat I''d go with used, but take an experienced sailor with you when you look at the used boat to buy it, because some rude people DO try to rip you off out there! Good luck & happy sailing!
Lane
  #12 (permalink)
Old 04-19-2001
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
Actually I have always found inboards easier to diagnose and to work on, especially in an emergency. This is one of those subjects where there is a real diversity of opinion. If you are handy and expect to do your own work, then inboards are way more reliable, the parts last much longer and regular maintenance tasks are less of a chore.
If you need to count on others to work on your engine then it is nice to be able to drop the engine off at a repair place and have them fix it.
  #13 (permalink)
Old 05-06-2001
neilstainton neilstainton is offline
neilstainton is on a distinguished road
Good day
I want to learn how to sail and have never sailed before. I come from a country called Namibia, in Africa. We have almost no inland water sources that are big enough for sailing(Only two to be exact.) This means that I will have to learn to sail on reasonably small lakes. First question, what boat do you suggest that I learn on and secondly, basically what sould I do?
Display Modes
vB code is On
HTML code is Off
repowering, where to start? ericamadio Gear & Maintenance 0 09-27-2004 06:53 PM
How do I start a sailing career? solbergg Cruising 0 03-07-2004 02:22 PM
How do I start? pilot2sailor Learning to Sail 4 10-03-2003 12:17 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
what type of boat,and where to start?? ajcjr Learning to Sail 1 07-10-2001 07:13 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
