05-07-2009
Super Moderator
A couple quick points;
It sounds like you guys are talking about twings and not tweakers. Tweakers adjust the lead on the genoa similar to a barberhauler or inhauler. Twings bring the lead for the guy to the deck at the point of maximum beam.. On a thirty foot boat, you can get by with a snatch block on the rail that you insert the guy into rather than going through the trouble of making up twing lines.
As a rule of thumb, spinnaker sheets are twice the length of the boat and genoa sheets are between 1 and 1.5 times the length of the boat depending on the overlap, use of turning blocks, and whether you have a furler. A jib sheet will be too short.
I would not bother with tapered spinnaker sheets for what you are doing, but the previous posters are right, 1/4" is way too light line for a spin sheet for 30 foot masthead rig boat.
The diameter of pole on the boat and its on deck storage sounds like a spinnaker pole, but if it is longer than the J of the boat and long enough to use as a whisker pole, then it probably is too long to use as a spinnaker pole. Denise's description only mentions trip lines and does not mention lift and downhaul bridles so the pole may actually be a whisker pole.
Faster is right that you will need to rig a pole downhaul, but it can be rigged from the bridle on the spin pole to the base of the mast so it does not need to be adjusted when you adjust the guy or during the jibe.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
