Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 06-09-2009
legarots is on a distinguished road
MOB in high winds without damaging jib?
For practicing the figure 8 man overboard, in 20+ knot winds, if you go head to wind, the jib will flog and probably tear. I was going to practice this in a 26' last time out, but I aborted when I noticed how much the jib starting flogging. I was training to let the jib luff after the first tack of the figure 8. How can you perform this maneuver without damaging the jib, on a 20+ knot wind day?
Old 06-09-2009
smackdaddy's Avatar
Last Man Standing
Watch Giu's video on heaving to. It's a great way to do the MOB and leaves you very close to the victim.
Old 06-09-2009
mrwuffles's Avatar
mrwuffles is on a distinguished road
You could just drop it if you get close enough or furl it if you have a roller furler
What's a signature?????
Old 06-09-2009
smackdaddy's Avatar
Last Man Standing
Wuff! Sup dude!
BTW leg - you probably want to do the tacking technique and not the gybe - unless of course you ARE the man.
Old 06-10-2009
ASA and PSIA Instructor
A jib in any kind of reasonable condition won't be damaged by short periods of flogging in 20+ knot winds - the jib flogs every time the boat is tacked. Do your MOB routine and don't worry about it.
Old 06-10-2009
noreault is on a distinguished road
It seems to me in a MOB situation, particularly in high wind, the first priority should be using the technique which yields a quick and successful recovery. Maybe it is just me, but equipment is a distant second.
Old 06-10-2009
smackdaddy's Avatar
Last Man Standing
Good point Noreault - especially if you're the one in the water.
Old 06-10-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
On the last leg of the figure 8 you turn the boat to the wind and coast up to you MOB. The main should be sheeted tight to the center line. You can also sheet down the head sail to the center line by using both sheets. But you risk having the bow blow off to one side of the wind or the other. It is best just to let it luff and get your MOB back on board.
Never Forgotten
Old 06-10-2009
I definitely agree that equipment is a distant second - in a real MOB situation. But there's no sense in tearing a jib just for practicing. Perhaps I should furl up the jib, and only use the main for the MOB drill, when winds are too strong...
Old 06-10-2009
... Perhaps I should furl up the jib, and only use the main for the MOB drill, when winds are too strong...
You gotta be kidding...20+ winds is just above a fresh breeze, you risk sail damage from practicing MOB maneuvers no more than when picking up a mooring at the end of the day. Sails are constructed to handle such wear-and-tear without damage...just don't leave it up overnight.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
With winds low, regatta woes high (Baltimore Sun) NewsReader News Feeds 0 04-30-2006 10:15 AM
Sailing Basics Steve Colgate Learning to Sail Articles 0 03-09-2003 07:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 07:00 PM
Wind Michael Carr Seamanship Articles 0 08-31-1997 08:00 PM
