Sailing "Downwind" - Page 2 - SailNet Community
post #11 of 24 Old 09-02-2009
many vangs can be used as preventers. mine will work that way if unhooked from the fitting at the base of the mast and led forward instead. I have enough line on it to reach from the attachment point at the front of the boat back to the cockpit so it can be untensioned from there if need be.
sck5 is offline
post #12 of 24 Old 09-02-2009 Thread Starter
Ok.. I know the fitting you are talking about, but I wonder if I have another one in front of the mast. Hmm.
But I do know that I have plenty of line to fully extend the boom perpendiculur to the boat. In that case. If I have that fitting in the front, I should connect and then tighten the line to keep the boom perpendiculur?
Sounds like a cool concept.
SpcAlan1 is offline
post #13 of 24 Old 09-02-2009
jjablonowski's Avatar
SpcAlan1,
For a preventer on my Catalina 25, I keep a carabiner (a shackle would do) attached to the end of my boom to give me a nice, big loop I can hook onto. Before I let the boom all the way out on a downwind run, I clip the end of a long length of some parachute cord I keep in the aft starboard locker.
After the boom is let out, I'll walk the preventer up to a forward stanchion and loop it under a support brace, then walk it back to the cockpit and cleat it.
I like using parachute cord because it's stretchy--a good thing for a preventer--and it's bright chartreuse and hard to miss and trip over. Also, it's light enough to do the job but it WILL break in the event of a knockdown, thus releasing the boom from the water--also a good thing.
As to the headsail, I find that the C25's mainsail often blankets the (roller-furled) genoa downwind, so I like to use a lightweight whisker pole, even when not running wing-on-wing.
Here's a concise video from pole-maker Forespar on using a whisker pole: Seafaring Magazine –Latitudes and Attitudes Television | Seafaring
jjablonowski is online now
post #14 of 24 Old 09-02-2009 Thread Starter
Well I am going to try that, but you just wrap the line around the stanchions?
Hmm, seems that would put stress on those. I wonder if I could move up one of my sliding blocks forward of the mast and "back-feed" it?
Hmm. Looks like I am going to the boat this afternoon and seeing what I can do.
Great idea....
SpcAlan1 is offline
post #15 of 24 Old 09-02-2009
AdamLein's Avatar
Hm. I found wing-on-wing trickiest in light air. Jib is most likely to collapse. Any speed you get means your apparent wind drops to zero. I think it's better to broad reach and jibe in winds under 5 kt, which takes advantage of the apparent wind coming forward better. In 5-10 I can maintain wing-on-wing much more easily.
Like US27, I'll often sail by the lee ever so slightly, since in reality the wind is still behind the line of the boom. Too much and you put the jib in the main's lee. Not enough and the wind is on the wrong side of the jib. If the jib collapses, I let the sheet out a bit. If it luffs or "folds" on itself I trim it in.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #16 of 24 Old 09-03-2009
We sail by-the-lee when wing-on-wing too.. it's really the only way to prevent constant collapsing of the headsail, esp without a whisker pole. In a good breeze going DDW wing-on-wing doesn't really give up much to a similar boat flying a spinnaker on the same heading. But it's nerve racking steering so tightly to avoid a gybe. We prefer to fly the spinnaker (up to a point) for that reason.
Faster is online now
post #17 of 24 Old 09-03-2009
Midwest Puddle Pirate
US27inKS's Avatar
A couple of weeks ago while racing on my friends Ranger 22, we did a little wing-on-wing-on-wing. The wind was howling, and we didn't want to get broached with the spin. We also didn't want to have our ass handed to us by just flying the 90% blade downwind. There is certainly not enough time to do a headsail change, then do it again at the downwind mark, so we were in a pickle. So I moved the spin pole downhaul out to the bow, then I clipped on the tack of the old worn out 150 we refer to as "the bedsheet". I hoisted the 150 using the spin halyard without hanking it on, and ran the sheet back to the spin blocks at the stern. The result was flying 2 headsails plus the main, and going more than a knot over hull speed for the downwind leg.
John USYacht 27 "Cora Lee"
US27inKS is offline
post #18 of 24 Old 09-03-2009
bheintz's Avatar
Yes, this is a good idea. The idea is something simple attached to strong points on the boom and the deck.
Also see:
Boom Brakes & Preventers - World Cruising and Sailing Forums
http://www.sailnet.com/forums/seamanship/1511-boom-preventer-not.html
Boom Vangs and Preventers - resources for cruising sailors
YouTube - Setting up a preventer to control the boom on a sailboat
YouTube - Rigging a Boom Preventer with a Shockle
bheintz is offline
post #19 of 24 Old 09-03-2009
Originally Posted by US27inKS View Post
....The result was flying 2 headsails plus the main, and going more than a knot over hull speed for the downwind leg.
And nobody protested you for that? Not sure it's strictly legal, nor is your rating likely to reflect that sail area.....
But as you saw, it works well...
post #20 of 24 Old 09-03-2009 Thread Starter
Hmm.. flying 2 head sails...
I wonder if I could do that...
I don't think so, since I have only 1 halyard ( and that is my roller ).
SpcAlan1 is offline
Cruising Multihull Sail Trim Kevin Jeffrey Buying a Boat Articles 0 10-05-2004 08:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
Great Books for Beginners Mark Matthews Gear and Maintenance Articles 0 01-27-2000 07:00 PM
