01-30-2010
Not to hash over what has been discussed before.
None of those cases mentioned what safety gear they had. In particular the Port Madison case as that is one of my favorite spots to go.
I'll ref as I know the conditions.
PNW waters are typically 40 degrees yr round (avg), go over board w or w/o a life vest... you have about 7 minutes before hypothermia sets in. Doesn't matter how fat, fit, or how mentally survival you think you are.
Lets get one thing straight - a lifesling is just a recovery device and it relies on the fact the one to be recovered is able to use it. Even harder, if you can already have crew with an a offshore lifevest. Most are not smart enough in panic to to just connect the line from the LifeSling to a d-ring on the lifevest (if so equipped), to allow them to be pulled with no personal interaction less making the connection. Here is the ultimate design flaw - LifeSling is designed for someone that doesn't have a life vest. Think about it. No way to put a Lifesling - foam or inflatable under your lifevest (assuming you do due diligence in outfitting the crew)...
It acts on the principle that the MOB is conscious enough to grab it, and designed assuming they have no lifevest. No way in heck you can get it the foam version or the auto inflate version (one of each on mine) if you have a functional inflating lifevest. Most that have Lifeslings do not have a 5:1 boom shackle device to handle the recovery effort to begin with (I do).
Something to think about as you contemplate you MOB procedures. Reason why not to rely on Lifesling - it is aux equipment. Your life vest should have d-rings and crew capable of bring the boat close enough that if it requires someone diving to connect a retrieval line - it can be done.
Fact - 90% off all that go overboard - are rendered unconscious within 5 minutes of doing so....
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
