Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 02-08-2010
pwillems's Avatar
Make it Happen
pwillems is on a distinguished road
Question My 15 year plan
Hi All,
My wife and I have recently decided that once the kids are all grown up and out of home, we are going to set sail and visit this planet. That gives us around 15 years to go from complete novices to confident sailors. 15 years is a long time, but I like long term goals, they help get though the daily slog.
At this point I'm trying to sketch out a plan for both of us to gain skills needed. For the sailing part, we are going to go through all the necessary courses available through the local yacht club and then find ourselves a spot as occasional crew at local events/races. What other skills should I be including in my plan? So far I am thinking of the following:
  • Marine radio and ham operator licences
  • Basic diesel engine maintenance and repair
  • Advanced navigation
  • Weather forecasting
Thanks for your help
Old 02-08-2010
night0wl's Avatar
night0wl is on a distinguished road
A lot of things can change in 15 years...including health and ability. Why not get a small trailerable or a small cruising boat and just enjoy weekends and vacations on the water. If you truly are a complete novice sailor, it makes sense to work your way up to cruising couple.
S/V Jendai
Beneteau 343
Old 02-08-2010
pwillems's Avatar
Make it Happen
That is of course most certainly part of our plan. We intend to spend 2 to 3 years just learning the ins and outs of sailing while crewing other boats before splashing out on a small cruiser for weekend outings of our own.
My question is more around other skills that a serious offshore sailor would need. We'd like to schedule some night courses down at the local adult learning center to make sure we can set out with a solid skillset when the day comes to cut the dock lines.
Old 02-08-2010
The following skill sets would also be helpful:
Fiberglass repair, especially if you're getting a GRP boat
Plumbing, since there are no plumbers at sea
basic 12 VDC electrical system troubleshooting and repair, also basic 120 VAC if you plan on having a shorepower, inverter or generator system aboard
small outboard maintenance and troubleshooting, since you'll probably have one for your dinghy
Basic splicing of double braid and three-strand ropes
Rigging repair and tuning—at least to the point where you can replace a stay and get the rigging back to where it should be after doing the replacement
Old 02-08-2010
Cal28's Avatar
Cal28 is on a distinguished road
reading and making notes ..
knowing I am going to be an extremely busy man ..
thanks sailingdog .. again
Old 02-09-2010
pwillems's Avatar
Make it Happen
Thank sailingdog. That is precisely the kind of information I am chasing.
Repped
Old 02-09-2010
Livia's Avatar
Vagabond in Training
Livia is on a distinguished road
Perhaps a Wilderness First Aid Course of some type?
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
Old 02-09-2010
Yes, a Wilderness First Responder or Wilderness EMT course would be an excellent addition to the skill set.
If you plan on having a refrigerator or A/C on your boat, learning the basics of refrigeration/A/C systems might be a good idea, if only so you can figure out what is wrong with the system and have someone repair it.
The more self-sufficient you are, the less expensive it will be for you to own your boat and for you to cruise it... and the further from civilization you can go. This is true of both you and the boat. A good cruising boat will have fairly decent passive electrical generation capability, like a combination of solar and wind, since fueling a generator is just foolish when the wind and sun are free. A watermaker is also a good addition on a lot of long-distance cruising boats...and between a water maker and a good passive electrical generation setup, you can stay out of marinas and harbors for a long time—since electricity, water, food and fuel are the most common reasons for coming into the marina.
Also, make sure that you setup the head on the boat so that the holding tank can be pumped out when you're out past the three-mile limit. My recommendation is to plumb the head directly into the holding tank and then to plumb the holding tank so that it can be emptied by a diaphragm pump through a seacock and through-hull or via a deck pumpout system. In many more remote areas, you will not find pumpout facilities, so having a way to empty the holding tank is a necessity.
Old 02-09-2010
sailguy40's Avatar
sailguy40 is on a distinguished road
Heck I am going to eventually have to learn all of that stuff too just to fix up my boat.
Old 02-09-2010
bakerha51's Avatar
bakerha51 is on a distinguished road
PW - I saw a thread recently from an older gentleman wanting to learn to sail and cross the Atlantic. One response contained an excellent list of skills but I don't seem to be able to find it. I'll keep looking - and maybe someone else has seem that as well.
Cheers
My 3-5 Year Plan toward the Cruising Life ChrisJuricich Cruising & Liveaboard Forum 62 02-03-2011 01:46 PM
From the Origin of Time to the Y2K Jim Sexton Seamanship Articles 0 10-14-1999 08:00 PM
