02-15-2010
A little more Lake P. advice, glad you followed the earlier advice, these were some pretty strong cold fronts so a honking N-NW wind, flat on the North shore, but nasty lee shore on the South Shore.
The lake, 20 by 30 miles, is only about *15* (count 'em) feet deep in most places. So instead of getting long rollers as you would in open water, you have the "square chop", which is steep with a very short wave period, and is hard on boats and harder still on the crew, hence the good advice you got and heeded.
I teach out there fairly often, on rather lightweight and low-freeboard sport boats, which won't take as much weather as a Cal-25. So I watch the weather carefully.
In looking at the NWS forecast, you would do well to look at the near-coastal (out to 25 miles) wind predictions rather than just the lake ones, especially if you're on the lee side of the lake. NWS typically cuts 5-10 knots off that windspeed range to get the lake prediction, but the lake has so much fetch that I think they're not conservative enough, and the offshore wind speeds are likely on the lake. So small craft advisories are *really* more like warnings.
If you want the real-time windspeeds on the South shore, go to southernyachtclub.org and click on "West End Weather", it gives you base winds, gust winds, and direction, all on the same graph. Also air and water temp, and barometer.
