Almost lost my boat today - Page 2 - SailNet Community
post #11 of 65 Old 02-12-2010
Sundance 23
carl762's Avatar
That's just downright scary. Glad you got the boat back in good condition. Ring the guy's phone off the hook, and get the deal done.
Water is Life
carl762 is offline
post #12 of 65 Old 02-12-2010
Sailguy
Sorry to hear of your problems but as stated before there are some people whom are nasty and don't respect others property. This kind of thing happens almost yearly where I have my 28', it is a private marina in a beach asscoation - private harbor. First of the year there are always one or two boats that become untied by themselves and if you are luck it just floats around the harbor, if unlucky its an out going tide and it makes it out of the breakwater. Last yr I had just brought the boat over and left it one night with out my cable lock got a call the next day it had floated three slips down and bouncing around between the fingers. They were to stupid to relies that in was incoming tide, luckly I had no damage. BUY A LOCK AND CABLE!!!!
Peter
"Justified"
justified is offline
post #13 of 65 Old 02-12-2010
Sundance 23
carl762's Avatar
I sure am going to buy locks and cables. Losing a boat would be devastating to me, even with insurance.
Water is Life
carl762 is offline
post #14 of 65 Old 02-12-2010 Thread Starter
sailguy40's Avatar
I was able to go to my boat today and quickly check for damage. I only seen the rubber bumber lining on the starboard side was torn off. Now here is the bad thing, I looked up at the mast and seen the horizontal cross bar up top that has the two lights on it, the right side of it is gone, got pulled off by the bridge and the support cable is just hanging there. Is this boat still ok to at least sail with the mast like this? Nothing is wrong with the main mast pole.
sailguy40 is offline
post #15 of 65 Old 02-12-2010
Somewhat Senior Member
mgmhead's Avatar
You must be kidding!
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #16 of 65 Old 02-12-2010
So, you're missing the starboard rubrail... is the hull-deck joint damaged? On many boats, the rubrail mounts over the joint and may have been damaged when it was torn off.
The horizontal bars are called spreaders, and if the starboard spreader is gone, then you can't sail the boat... you're lucky you didn't lose the mast... and you should probably run a halyard down to the starboard side to help support the mast.
sailingdog is offline
post #17 of 65 Old 02-12-2010 Thread Starter
sailguy40's Avatar
I will be doing a thorough inspection of the boat tomorrow. Hopefully the hull-deck joint is not damaged. I mean I just bought this boat, only had it for 5 days and only left it alone for 1 day and in what was supposed to be a good area! I may end up having to sell this boat now, I am not buying a whole mast already. If the mast needs work, that means it needs to be taken down. I don't know anything about working on a mast. Also the little wind vain is broken, so a new sailor needs this and I don't have it now. I am wondering if I can buy these spreaders seperately? If the mast would have been like this, I would have never bought the boat. The mast was in very good shape, thats what is ashame.
post #18 of 65 Old 02-12-2010
As long as the mast hasn't been damaged... you can probably replace the spreader and shroud.
post #19 of 65 Old 02-12-2010
Sunsets and Warm Beer....
LandLocked66c's Avatar
Not a big deal man. If you're going to own a boat, better learn how to work on them as well. Pretty much goes hand in hand. Either that or be willing to pay someone else to fix it for you. Good luck man, she's a beauty - it'd be a shame to see her go so soon...
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #20 of 65 Old 02-13-2010 Thread Starter
sailguy40's Avatar
Well, I tell you man after looking online, it seems darn near impossible to find something better then what I bought. It just seems like a really good sturdy boat to me and I read a lot of positive things about the CAL 25s both online and in a book. Its big, seems easy to sail and learn on plus it can grow with me. Now that I can't sail it, I better start looking for a good outboard and find it quick or I will never get it away from where its at. The little minn kota 50# was ok to get in and out the docks but it certainly wont make it across the lake. I need the sails for that or at least an 8-10 hp outboard.
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
How to Choose the Right Boat Don Casey Cruising Articles 0 04-20-1999 08:00 PM
