05-05-2010
Custom Member
I know this doesn't apply to your boat, but, since I've seen so many folks complain about reverse in smaller sail boats (less that 35'), I thought I'd chime in for those of us that have outboard motors.
Maneuvering in reverse in ANY smaller sailboat is overwhelmingly difficult for the learning skipper. I figured it out the hard way, but fortunately fairly early on... To maneuver in reverse with an outboard mounted on the center of the stern (NOT offset), you need to manipulate two pieces- the motor itself, and the tiller. Point the prop in the direction you want your stern to go, and use the tiller to manipulate the bow. Leaving the motor "centered" causes the bow to move, but the stern respond in time, so you wander. Find some bouys and practice on a calm day. I can thread a needle in reverse now with a 25' sailboat.
-Mike
