Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 05-31-2010
jreese is on a distinguished road
Name that Rigging
I have a Santana 22 with a sheave box built into the forward side of the mast about half way up to the mast head. A halyard runs up the mast, into the sheave box, back down the mast on the inside, out the base of the mast on the starboard side and back to the cockpit by way of a block at the base of the mast.
This is the only halyard of four on this boat that does not run to the mast head.
Any help with identifying intended use would be greatly appreciated.
Old 05-31-2010
celenoglu's Avatar
celenoglu is on a distinguished road
That should be the upper support line for spinnaker pole
Old 05-31-2010
Agreed ....AKA the "pole lift" or 'uphaul". If you still have the spinnaker gear, there should also be a 'downhaul' rigged on deck, a track or a ring on the front of the mast down low, and, of course, the pole itself.
1984 Fast/Nicholson 345
Old 05-31-2010
Thank you both for your help.
Old 05-31-2010
nolatom will become famous soon enough
also known as just the "topping lift".
(yes, there's one on the boom too, but it never gets adjusted underway, or ever really, so no chance of confusion)
Under spinny, tactician/trimmer will usually just say, "pole up (down) a little", or similar.
Standing Rigging: Some Questions sailjunkie Gear & Maintenance 7 03-24-2010 05:51 PM
Sailboat Rigging Danger eherlihy Gear & Maintenance 8 11-18-2009 03:40 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 08:00 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 07:00 PM
Standing Rigging Storage Jerry Hammill Gear and Maintenance Articles 0 10-15-2001 08:00 PM
