07-02-2010
Originally Posted by cb32863
I am looking for some advice on learning to single hand. There are going to be times when I will want to be sailing and the kids, well they are teenagers...... I am thinking the actual sailing part won't be too much of an issue. The boat I regularly sail is a Pearson 26 with an outboard and I have no problem reaching lines and what not. It has a roller furler jib as well. I am thinking that getting in and out of the slip is going to be the most difficult thing. Stopping as I come in I think would be the biggest issue. Anyone have any techniques they use to get in and out of the slip on thier own? Thanks!
There are a few good things about what you have, 1) with a boat that size you are able to use your hands and feet to push it around and keep it from crashing into the dock, etc, which is a big help, it just isn't that heavy and as long as you don't really ram it in there you can stop it with your foot. 2) Using an outboard that has reverse on it you can turn the outboard in different directions and do some tricks that a boat with an inboard really can't do. The biggest thing with bringing your boat into the slip alone is going to be getting a line on/from the pile that's between you and the next slip, the one that you can't walk to, if you can catch that line as you are coming in to dock then you've got it made, but if you miss it then it is going to be much harder to get later, so have that boat hook handy! Same thing when leaving, you have to put the line up so you can get it back when you bring the boat back in. As always, take it slow. You can pretty much get the boat drifting into the slip then leave the cockpit and get the lines all arranged as you are coming into the dock. Edit-- as for technique, on that boat you'd probably just get the line off the hard to reach pile as you are drifting into your slip then quickly grab the line from the other side and just use those two lines to slow the boat down, then tie them off and quickly move to the other end of the boat at the dock end and tie those lines off, then adjust all of them. That's what I would do.
What are you pretending not to know ?
Reason: Edit
