Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #11 (permalink)
Old 09-15-2010
CaptainForce's Avatar
Back to the topic of attaching the tack. If the bow pulpit or other hardware distorts or chafes your sail and the head of the sail has space remaining to be hoisted higher; it may be appropriate for you to add a length of wire rope to the tack. This is referred to as a tack pennant and it may improve your sails shape and lifespan. Tack pennants are normally just a few inches to a foot long for most vessels.
When attaching sheets to the clew, tie them on. Some use a shackle, but this is a risk for head injury when handling a flogging sail.
Take care and joy, Aythya crew
  #12 (permalink)
Old 09-15-2010
Robert—
Your questions are very basic, and I would highly suggest you get a good sailing primer, like Dave Seidman's The Complete Sailor, about $16 at the local bookstore. This will answer a lot of your basic questions, as well as give you a lot of useful information.
The sheets need to be secured to the clew of the sail so they can control it. If you use a single long sheet for both sides, you'll probably want to use a cow hitch or larkshead knot to secure it. If you use separate sheets for each side, you'll probably want to use a bowline on each.
As CF said, don't use a shackle on the clew, since it becomes a fairly lethal object when the sail is flogging. The bowlines may hurt, but won't kill you.
c&c 30 mki a,b,c,etc.. question Csobanc Boat Review and Purchase Forum 1 01-28-2010 08:11 PM
To Ac or not to AC, that is the question Mimsy Gear & Maintenance 17 03-31-2009 02:24 PM
A Question for CD PBzeer Politics/Religion/War/Government 44 03-29-2009 11:29 PM
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
new guy question... gforcepdx General Discussion (sailing related) 1 11-20-2006 03:28 AM
