09-26-2010
Hi Tanley,
So, Practicing heaving-to in varying conditions is good, so you know how your particular boat behaves. I use it all the time..even for a quick lunch, rather than anchoring..! If you heave-to on a starboard tack..then you may retain some privilege. Saves dropping all the sails and the anchor..if you just want to take a break for awhile.
I will usually roll my furler up to the point where it's in front of the mast...this way, when it's backed I'm not chafing the sail or putting stress on the spreaders..or shrouds.....then heave-to and deal with the main.
Every boat will behave differently....if there's a current you may have to adjust the rudder position. I did it today on the Hudson River..
Tempest
Sabre 34
Morgan, NJ
