Actually using Charts - SailNet Community
post #1 of 4 Old 05-05-2003 Thread Starter
cmendoza's Avatar
OK, I''ve got charts and I know how to use them...
One question. You don''t actually write on the darn things do you?
I''m assuming you overlay them with something?
Can''t believe that these things are single use items.
Any and all help would be appreciated.
Regards,
Carlos
cmendoza is offline
post #2 of 4 Old 05-05-2003
Moderator
Jeff_H's Avatar
If I am sailing a route that I am likely to sail again I will layout my courses with a very sharp pencil and label the courses so that I can use them again. On a long passages in order to log my positions, I carry 3x5 cards and make notes every half hour or so on speed, course, and position. With GPS I check the positions on the chart but generally do not bother to plot all of these points on the chart. Before GPS, I made more frequent notes and I kept a running DR position which I marked lightly on the chart in soft sharp pencil.
Jeff_H is offline
post #3 of 4 Old 05-06-2003
just write directly on the chart
what you need is a 2B pencil, these are soft enough to be rubbed off by an eraser
bullseye is offline
post #4 of 4 Old 05-06-2003 Thread Starter
cmendoza's Avatar
Thanks Jeff, Bullseye... appreciate the input.
cmendoza is offline
Best place to get charts SE Asia sneuman Cruising & Liveaboard Forum 1 09-14-2004 07:28 AM
GPS and electronic charts? Jhooley Gear & Maintenance 4 03-18-2004 05:52 AM
Electronic Charts for Trade/Barter svGandalf General Discussion (sailing related) 1 12-11-2003 02:06 AM
Caribbean Charts DICKWATERS Cruising & Liveaboard Forum 3 08-11-2002 02:32 AM
Bahamas Charts?? VIEXILE Cruising & Liveaboard Forum 3 01-15-2002 05:41 AM
