outboard reverse - SailNet Community
post #1 of 11 Old 05-19-2003 Thread Starter
outboard reverse
I just purchased a 26'' laguna with a early 90''s model 9 hp evinrude outboard. The problem I am having is getting out of my slip in reverse. Does anyone have any pointers on steering a sailboat in reverse with the rudder. The boat just wants to go where the motor pulls it. You can crank and crank on the till to try and turn it but it stills goes one direction (straight back) anyone have any advice
cedarpines is offline
post #2 of 11 Old 05-19-2003
outboard reverse
Your problem is not unique. The secret is establishing enough hull speed to get steerage from the keel and rudder. It sounds like the location of your outboard creates enough turbulence to destroy flow over the rudder.
A couple of things to try:
1) Establish a movement astern with the OB, shift into neutral. Helm should return to rudder control. Alternate between OB and rudder as needed. Two people may be required.
2) Unlock the pivot on the OB and rotated it to steer the boat. Coordinate the rudder with this action.
I don''t know the configuration of your rudder, but another option may be rotating the rudder 180 degrees to reduce the caster action when going astern. This gets me steerage at lower speeds.
Now, add a little wind to this equation and the comfort zone disappears again!!
Hope this helps,
jparker11 is offline
post #3 of 11 Old 05-19-2003 Thread Starter
outboard reverse
Thank you for the tips. I''ll try alternating from reverse to neutral and see if that helps. I''ve tried to look for the motor pivot lock to unlock it and steer the boat in reverse but I cant seem to find one on this particular motor.
post #4 of 11 Old 05-19-2003
pirateofcapeann's Avatar
outboard reverse
When life gives you lemons, make lemonade! When backing, lock the tiller in the center position and steer with the motor. Don''t be afraid to use forward thrust to pivot the boat into a position. Once you get the hang of this, you''ll be the envy of the marina, being able to out maneuver all of the inboard boats!
pirateofcapeann is offline
post #5 of 11 Old 05-20-2003
outboard reverse
Finding and releasing your motor pivot lock will solve your problems. When you can pivot your outboard, you can point the thrust in any direction, and turn the boat by using the propeller thrust, instead of by using the rudder.
Sailormon6 is offline
post #6 of 11 Old 07-17-2003
outboard reverse
I have seen a device that links the tiller with the outboard so they turn in unison , it ought to make going backwards or forward easy
KenD is offline
post #7 of 11 Old 07-22-2003
gwp
outboard reverse
Oday 25
I have no problem manuvering into my slip by turning the tiller and the outboard in unisen. You must stay mindful of the fact that without hull speed, you have no steering capability. It can be turned on a dime using this method, even when wind is a factor.
gwp is offline
post #8 of 11 Old 07-26-2003
outboard reverse
KenD and GWP,
Do you have any idea where to get the info on the gear to tie the boat''s tiller and the tiller on the motor together? I''ve been looking for something like that, but have not been able to find it. Also, will this work for a motor that sits in a well?
Thanks,
Peter K.
waltzingmatilda is offline
post #9 of 11 Old 08-01-2003
outboard reverse
Cedarpines,
If you look at the thread on singlehanded docking, you''ll see that I had the same problem. I thank everyone for their great advice, and I have to say that one of the guys moored in my new marina is a mechanic and it took him all of 4 seconds to locate the retention bolt on my Johnson 9.9.
I had asked several experienced cruisers about pivoting the outboard, but they were all blue water sailors and just said they didn''t think outboards were mounted to turn. So, for years I struggled with bad performance in reverse. Now I can spin my boat on its swing keel like a top, making maneuvering and docking incredibly easy.
My advice is to go to a store that sells power boats and ask the mechanic where the retention bolt is on your engine.
Best to you,
Chas
flicker is offline
post #10 of 11 Old 09-16-2003
outboard reverse
Hi Waltzingmatilda!
I have an EZSteer device that does attach to the rudder stem and the motor so they do turn in unisen.....never used.
Don''t know about the fact that your motor sits in a well. May not work. Check at a marine store for info. Then, get back to me.
Luck!
Boatinbabe (9-17-03)
boatinbabe is offline
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
OutBoard Motor Bracket for Peason 424 aphil138 General Discussion (sailing related) 1 06-08-2004 01:49 AM
outboard zincs SteveHill Gear & Maintenance 1 01-01-2004 10:32 AM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
