Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 01-07-2011
lapworth is on a distinguished road
Do navigation lights move faster when near ?
I was coming home last night and noticed a plane flying by and he was going fast over the horizon. I know with a motor boat this would make as much sense because they can change there speed. So what I was wondering is could you get a better feel for the distance of a boat from you by how fast they are moving over the water ( I know there not moving faster @ closer distance ).
Old 01-07-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Perception is everything.
The questions that you're trying to answer are:
Is this a small, dimly lit vessel crossing me close by or
Is this a large, brightly lit vessel crossing me far away?
They might look very similar.
Things you can do to help determine this are to observe how high off of the water the lights are. That might indicate a larger vessel if they're high off the water.
Then you observe how fast the lights are moving past fixed points on land (or fixed lights if you can't make out a land feature). Also, if you suspect that the vessel might be close aboard, listen for engine and wake noises (though you might not hear any.)
S/V Old Shoes
1973 Pearson 30 #255
Old 01-07-2011
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
By "light's moving faster", you might mean changing their relative bearing to you. In other words, you are turning your neck as you watch the lights.
I'd only add that the change in bearing to the light can tell you something, but not enough without BubbleHeads' answers.
A faster bearing change will happen if the boat is
closer
faster
not heading to intercept you (If he's going to hit you there will be no bearing change.)
Also, the perceived height angle (azimuth) could change fast, but by then it's probaly too late.
Regards,
Brad
Old 01-07-2011
Let me try to word this another way. If I see a sail boats port light cross in front of me over the horizon and it is sailing at 5 knts about a mile away would it take the same amount of time to cross 5 degrees of vision as if the same boat was 2 ml away still doing 5 knts.
Old 01-07-2011
acunningham is on a distinguished road
No, it would take about half the time.
Old 01-07-2011
jrd22's Avatar
Courtney the Dancer
The lights you see that are "moving" aren't the ones that are the most dangerous to you.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 01-07-2011
Then I should be able to make a device that could estimate distance of moving objects. Maybe something similar to the way you use a sextant on a bridge or light house.
Old 01-07-2011
That would work, as long as you know the speed and angle the object is moving at. Of course, you could ask them via radio :-)
Old 01-07-2011
I could use it other ways. If I know it is in the channel and I know how far away I am then I would be able to calculate there speed.
Old 01-07-2011
Very true! If they're in the channel you can make reasonable estimates of both their distance and their course. Isn't mathematics wonderful?
LED Navigation Lights solman55 Gear & Maintenance 14 10-29-2010 09:06 PM
Navigation Lights tager Electronics 42 11-07-2009 08:35 AM
Navigation Lights Guidera48 Gear & Maintenance 10 07-24-2009 05:27 PM
Navigation Lights sailaway21 Seamanship 44 06-04-2007 12:46 AM
Navigation Lights 1970Columbia34 Gear & Maintenance 9 02-28-2007 10:29 PM
