Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #11 (permalink)
Old 03-20-2011
moorehal is on a distinguished road
Good idea on the ID #...my club has several Capri/Catalina 22s with the wing keel. The 4 ft keel boat looks totally different on a trailer. Another option: if the boat comes with a trailer, look at the trailer. It should be substantially higher than the one in the photo.
The owner doesn't know?
  #12 (permalink)
Old 05-21-2011
oceanrey is on a distinguished road
1970 Catalina 22 Keel Problem
Does anyone know of a retrofit kit to convert the single bolt thru hull swing keel into one that does not leak? Or, a better way to install or torque original design to prevent leaking. Mine leaks a fair amount every time I use it. I finally after many years dropped the keel out and am trying to put it back together in a better way.
  #13 (permalink)
Old 05-23-2011
puddinlegs is on a distinguished road
Most production boats have an association website... a quick google search says:
Catalina 22 National Sailing Association
I'm guessing they'll have good suggestions.
  #14 (permalink)
Old 05-23-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
If the water is clear enough, and the boat is in a slip with fingers on either side, have a friend stand on one finger and pull on a shroud to tip the boat a bit while you look under it from the other finger. You should be able to see the whether the keel is a fin or wing pretty easily.
  #15 (permalink)
Old 05-23-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Or grab a halyard and walk it abeam.
  #16 (permalink)
Old 07-28-2011
rightbrainer is on a distinguished road
Take a boat hook and see if there's a wing under there when you poke around. They aren't small. Is the rudder the same between the two models?
New sailors request help -- catalina 27? rconn2 Boat Reviews 26 10-18-2010 08:05 PM
Catalina 30 Keel cracks (not Catalina Smile) Pelham Catalina 5 12-01-2009 10:39 AM
Re: Connecting Sailors to Sailboats / or Sailors to Sailors NewsReader Mass Bay Sailors 0 05-25-2007 12:15 AM
catalina 34 Mark II or catalina 350 casey1004 Boat Review and Purchase Forum 11 06-13-2003 04:39 PM
