Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 04-23-2011
gary1946 is on a distinguished road
replacing halyard
hi everyone,
question, i have a freedom 25 and need to change the mainsail halyard ..can i run a messager tied to it up and then put the new line through that way or do i have to climb
thanks
gary
Old 04-23-2011
anemoneii is on a distinguished road
Messenger line will work well, I remove my halyards every winter to keep them "new"
Old 04-23-2011
justified is on a distinguished road
A messenger will work just make sure that you have a strong connection between the messenger and the halyard and a long smooth tapper so it won't get hung up as you go threw the shive. I found out the hard way.
Peter
s/v Frayed
Old 04-23-2011
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
I sew, and then place shrink to fit over the sewing of the 2 ends.The shrink to fit shrinks the sewn area, so it doesn't hang up........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 04-23-2011
thanks to all of you this freedom rig is new to me iam use the ss cables so its a learning curve
Old 04-24-2011
QuickMick's Avatar
QuickMick is on a distinguished road
when i butt the lines together, i take a paperclip and bend it into an 's' shape and kinda snake the tape through it, as it gives you more strength at the joint. Do Not use too much tape or it may get jammed in the sheeve (learned the hard way, lol, seperated the joint-this was pre paperclip trick-both lines came raining down and i had to go up anyway)
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 04-24-2011
Tempest is on a distinguished road
I use Imagine to Frolic's method...Sew the two but ends together and then I wrap the joint with a little overlap in Atomic tape very tightly to make a smooth transition. It needs to roll over the Sheeve smoothly
I use a carpet thread to sew. The sewing is just a little extra insurance imo.
You can usually feel when the butt joint gets to the sheeve, a slight extra downward presssure on the pull side, with some pressure on the feed side will help turn it in the right direction. If it hangs up, don't force it, just back off and try it again. Not that difficult at all.
Tempest
Sabre 34
Morgan, NJ
Old 04-24-2011
celenoglu's Avatar
celenoglu is on a distinguished road
you can also useat shrink tubing from an electronics shop. You can directly add the new one to the old one end by end and heat shrink the tube. the tube becomes a lot much softer after it shrinks.
Old 04-24-2011
Gary M's Avatar
Gary M is on a distinguished road
I just use duct tape, carefully applied to the two lines butt ended together, and have never had a problem.
Gary
Old 04-24-2011
Heat shrink tubing sounds like a great way to go...I will definitely
try that next time
Tempest
Sabre 34
Morgan, NJ
Replacing a Wire Halyard Winch alofns Gear & Maintenance 8 03-20-2010 09:54 PM
Replacing wire halyard with cord bobmcgov Gear & Maintenance 1 08-22-2009 12:38 AM
?jib halyard Loualfr Gear & Maintenance 8 08-02-2007 07:45 PM
halyard egregerson Ericson 9 11-09-2006 02:26 PM
jib halyard jbarros Gear & Maintenance 1 06-05-2003 03:36 PM
