06-18-2011
run the lines to the cockpit, and put a downhaul on the jib, this way it is stuck down till you need to raise it,
main first, and as lifting once boom moves de tach the topping lift and tighten in
then jib depending on which way i will be heading i pull that side sheet line taught with two wraps on the winch, this keeps it but can allow it some slack if needed.
then adjust jib, main and off to the races, kick back snap tab of bud lime and relax
