06-23-2011
Something to consider:
Your boat responds to forces by trying to pivot about some center point, for sake of this discussion, let's say about its middle or keel location. The main force trying to turn you is the wind. If you put up a head sail with no mainsail, the wind against the head sail is trying to push your bow down wind....the opposite of where you are trying to go in a tack. If you have only a mainsail up, the wind will be trying to push your stern down wind. If you have both sails up and adjust sizes on each end (smaller/larger headsail, full or reefed main, or adjust the forces on each sail by how hard it is sheeted in) you can achieve a balance. Typically, for good control, sailboats adjust sails so that in a normal configuration, there is a little weather helm....not too much or you will be fighting the weather helm with the rudder, which will then tend to act as a brake. So with one sail up, your boat is unbalanced. Put up both the mainsail and standard jib and your boat will respond better. They will sail with only one of these sails, but doing so affects how the boat handles and what it can do, as you have experienced.
The rudder has no control unless there is sufficient water flow past it such that the water pressure against the rudder, when you turn it, is enough to offset the single foresail's attempt to push the bow down wind. As you tack the boat, it will slow from the turn, creating a situation where the forces attempting to push the bow down wind, due to just a jib being used, are balanced with the rudder forces attempting to push your bow upwind. When that happens, you will have no rudder control. Balance your sails and get the boat moving, then you should have control.
At some low level of wind, any boat, regardless of number and size of sails will not have rudder control. Water flow past the rudder, i.e. control, occurs only when the boat is moving forward (or backward under motor). To create this water flow, you must make the boat move. The wind against the sails, with sails acting like a airplane wing, creates the forces necessary to move the boat forward, thus giving you flow over the rudder, and control. When the wind forces on the sail are so low that they cannot offset the water drag on the boat, the boat will not move forward, the rudder becomes useless and the boat will essentially stop in the water. When this happens, it's time to take the sails down and start the engine. 5 kts. is approaching that point....usually about 4kts. on my boat.
Hope this helps. Good luck.
