Staying onboard at the bow - Page 2 - SailNet Community
post #11 of 27 Old 07-27-2011
when working on the hanks wrap one arm around the forestay - that should let you use both hands and not break the "one hand for the boat" rule.
zibadun is offline
post #12 of 27 Old 07-28-2011
MikeinLA's Avatar
I have had to go to the bow in rough weather a few times when I was alone. I have absolutely NO problem in popping out of the forward hatch and crawling the 6-7 feet to the bow. I tend to sit once I'm there to keep weight low. Oh, and DO clip on to something.
Mike
MikeinLA is offline
post #13 of 27 Old 07-28-2011 Thread Starter
Barquito
Barquito's Avatar
I think I am getting foredeck envy, mine is only 4-5 feet to the bow.
Barquito is offline
post #14 of 27 Old 07-28-2011
AdamLein's Avatar
Originally Posted by WDSchock View Post
place bottom firmly in bow pulpit facing aft feet spread apart jammed against toerails, if foresail was folded with some forethought, the luff will be accessible while most of sail remains in bag.
This is what I do. I sit right on the bottom rail of the pulpit. Keeps the wind out of my face, gives me both hands, and is actually kind of relaxing compared to squatting on the foredeck.
Everybody who told you to make sure you clip on is doing you a disservice, since I'm sure you're doing that already. Clipping on doesn't keep you in place, just makes it not impossible for your crew to find you, and slightly less impossible to climb back aboard solo.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #15 of 27 Old 07-28-2011 Thread Starter
Barquito
Barquito's Avatar
Maybe add a super short tether? I just can't imagine being out in the middle of Lake Michigan by myself, w/o being attached to the boat.
Barquito is offline
post #16 of 27 Old 07-28-2011
CaptainForce's Avatar
Originally Posted by AdamLein View Post
.............Clipping on doesn't keep you in place, just makes it not impossible for your crew to find you, and slightly less impossible to climb back aboard solo.
Right! 'sounds like the man that won't wear a seatbelt on the highway. I never understood that as a way to celebratge freedom, but go ahead! 'knock yourself out! Take care and joy, Aythya crew
CaptainForce is offline
post #17 of 27 Old 07-28-2011
Senior in age only!!!
centaursailor's Avatar
I admire a bit of good old fashioned bravado, but advising against clipping on at the bow in rough seas seems a tad reckless.
I suppose wearing a life jacket would be considered ostentatious.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #18 of 27 Old 07-28-2011
AdamLein's Avatar
I didn't advise against clipping on, folks. I said that recommending it isn't helping. The conversation went kind of like this:
The OP: Hey, how do I stay safe working right at the forestay?
Everybody: Just clip in, you'll be fine.
Adam: Is that all? At least *one* person suggested using a rigid part of the boat for support.
Read before you comment, folks. Nowhere do I say not to clip in. I just pointed out that clipping in serves a different purpose than most folks here seems to believe.
The bow of my boat is about two feet wide where I'm kneeling to hank on a jib. Even a short tether is not going to do much to keep me on the deck.
FWIW I'm usually clipped in when out of the cockpit, but only for the reasons I mentioned, not because I believe it will prevent me from falling overboard.
AdamLein is offline
post #19 of 27 Old 07-28-2011
........ Clipping on doesn't keep you in place................
Actually, we are reading, but I think this phrase is where our thoughts diverged. You seem to favor being braced against strong points and being clipped in represents a safeguard that doesn't hold you in place and can even leave you suspended over the rail. You are absolutely right if this is the way you use the teather; however, if you have a short teather fixed to a strong point or even two teathers, then your pull in a stance against the hold of the teather will keep you in place. I don't think there is a big divide here, but just a different way that we might use the teather.
post #20 of 27 Old 07-28-2011 Thread Starter
Barquito
Barquito's Avatar
I agree. That is the problem, the tether keeps you safer up until you get far enough forward that you could go over the lifeline and just hang there. I doubt it would be safer to unclip at the bow, but I realize the tether won't always keep me on the boat that far up.
Barquito is offline
Staying Online-Offshore help codmander Gear & Maintenance 17 08-05-2009 03:29 AM
Staying Warm Classic30 Gear & Maintenance 8 04-21-2008 04:46 AM
Staying Warm and Dry at Sea YachtRacerMan Gear & Maintenance 63 03-11-2008 04:33 PM
Staying longer in Europe Seagypsywoman Cruising & Liveaboard Forum 7 01-25-2005 02:04 AM
Staying Dry and Warm John Rousmaniere Gear and Maintenance Articles 0 11-26-2002 08:00 PM
