Go Back   SailNet Community > General Interest Forums > Learning to Sail
Like Tree1Likes
Old 07-31-2011
Slayer's Avatar
Slayer is on a distinguished road
Identifying windward boat
I sometimes find it difficult to determine which is the windward boat while sailing a beat along side another sailboat on the same tack. (To determine right of way) I think it is because the wind is blowing on the nose of each boat and one may even be a little ahead of the other, making it appear to be the "windward" boat, even though that may not be the case.
But it dawned on me to just look at the sails. For instance, if you are both on a port tack, I believe the boat whose boom end is angled toward the other boat is the windward boat, regardless of which boat is ahead of the other on the line. Is this an accurate way to determine leeward/windward?
Old 07-31-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I might not be understanding your question (or know the answer), but if you are on a port tack wouldn't anything you see off of the port side be windward of you? Doesn't matter if they are ahead or behind, they are still windward.
Old 07-31-2011
Slayer's Avatar
I think that is my answer. I was just looking at it a little differently. So on that tack, anything to your port is windward?
Old 07-31-2011
Gary M's Avatar
Gary M is on a distinguished road
Yes, anyone to windward of you.
Old 07-31-2011
sailpower's Avatar
sailpower is on a distinguished road
Yes but you were also right although the other explanation is easier to remember.
BTW, years ago I was always trying to figure out which way the wind was shifting and whether that was backing or veering and would I be lifted or headed.
I came up with this: “Backs Left Port Lifted”. Easy to remember as Left and Port are together and Left and Lifted both start with L.
Once you know that then you also know the opposite; Veers Right Starboard Lifted”.
And of course if you are not being lifted then you are being headed.
The first one is the easier to remember and gives you the second.
Old 07-31-2011
puddinlegs is on a distinguished road
If you were on a beam reach sailing perpendicular to the wind, yes, what you say would be true, but if you were sailing close hulled, a boat on the same tack seen off your quarter might not be windward at all. In a quick nutshell, there are two points of reference that you can use. One is the wind, the other your boat.
Reference 1, wind direction:
Look at your masthead fly (not where your boat is pointing). That's where the wind is coming from. Now imagine a line perpendicular your masthead fly. Anything between your bow looking straight ahead in one glance, then in the direction of the wind and that imaginary line is to windward and ahead of you. At a certain point, if you imagined tacking and could cross clear ahead, they're too far behind to be the windward boat. It's difficult to judge when boats are near that imaginary line because different boats have different tacking angles and pointing ability. Some sailors see it more clearly than others. In racing it is both an art and skill that is incredibly valuable.
The second reference is your boat:
Imagine you're sailing upwind as high as you can point. You might see a boat ahead a few hundred yards and to the lee side of your bow at roughly 11 o'clock. You might describe it as being leeward of your bow and tell the skipper, there's a boat ahead and to leeward. Practically speaking, while he's to 'leeward' of you, he's far enough ahead that he'll be able to tack and cross your bow. Now in both frames of reference, he's a windward boat!
Old 07-31-2011
Slayer's Avatar
I appreciate the feedback,,,,but if I am reading all answers correctly, we have a divergence of opinions. I think I need more clarification.
Old 07-31-2011
sailpower's Avatar
Not sure what you are trying to say here. In your initial report to the skipper the other boat is to leeward and that is a correct report. IF he tacks he would then be to windward but not before.
If you are trying to point out that there are differentt right of way strategies other than windward/leeward then sure but I don't think that was the question.
Old 07-31-2011
Barquito's Avatar
Barquito
I agree with sailpower. If you aren't going to hit each other it really doesn't matter. If you are on a port tack and turn left, and ram someone, they were on the windward side of the boat.
When boats are on the same tack and overlapped, the boat to windward (the boat closest to the wind) shall keep clear of a leeward boat (Rule 11).
I don't race, so for some reason I always get the windward/leeward rule confused. I guess that it makes sense. If the windward boat wasn't close hauled, it would be their responsibility to head up. The windward boat also has room to tack, the leeward (overlapped) boat would hit the windward boat tacking, so their only escape is a gybe.
Old 08-01-2011
MarkSF is on a distinguished road
" The windward boat also has room to tack, the leeward (overlapped) boat would hit the windward boat tacking, so their only escape is a gybe.[/QUOTE]
The rule never made sense to me until you put it that way.
Help identifying boat Infinetic General Discussion (sailing related) 6 08-29-2010 01:21 PM
Help with Identifying a Boat JEHolden Boat Review and Purchase Forum 5 06-26-2010 07:20 AM
Good boat designs for sails windward quicksilver512 General Discussion (sailing related) 13 01-19-2010 07:33 AM
Help identifying a boat recvpoor General Discussion (sailing related) 2 12-29-2009 07:29 PM
Need Help Identifying a boat newbie13 General Discussion (sailing related) 17 05-24-2009 10:48 PM
