Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #11
Old 08-15-2011
PaulfromNWOnt's Avatar
PaulfromNWOnt is on a distinguished road
I should add that I met a fellow a few weeks ago who referred to his engine as a "Decoration" on the stern. Everywhere he goes he sails (narrow channels and all).
He's sailed up the west coast to Alaska twice without an engine, and swears by it.
  #12
Old 08-15-2011
Mark1948 is on a distinguished road
In my area (Milwaukee) most training is done on boats without a motor - Ensings and Yinglings so its is the learning norm ranther than the unsusual. It was certainly a benefit to me when my trasmission went out.
  #13
Old 08-15-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Originally Posted by CorvetteGuy View Post
Even a small 2 horse air cooled outboard will not add weight but will add peice of mind when needed.
Maybe. It depends on the boat, the skipper, the way the outboard is rigged and how easy (or difficult) it is to operate from the cockpit.
I've seen people get into a lot of trouble - and cause a lot of damage - trying to get an undersized outboard in gear at the last minute (that won't stop them them anyway) when they should have been concentrating on what was happening in and around the boat and fending off instead.
Boats in our fleet that usually sail without engines might carry an outboard - but it isn't on the stern or running when they come in. It's down below, ready to take them home on a flat calm day...
In my experience, you either come in under engine or sail - not both. Having a noisy outboard on the back ready to snag lines and distract crew is really not going to help you get in safely.
"Only two sailors in my experience never ran aground: one never left port and the other was an atrocious liar.." - Don Bamford
  #14
Old 08-15-2011
Hartley18's Avatar
Termite Fodder
Originally Posted by SHNOOL View Post
When we came in with no motor, in 15 knot winds... I was flying a reefed main only (keeping sail area simple, and tacking pretty hands free). Spilling wind on my way in. We were doing 2.5 knots on a port reach, at the end of the dock... 80 feet away was our slip (and 90 degrees in, and into the wind). I instructed crew, what was happening.. no time for topping lifts, or the like, boom was going into the cockpit at speed, and I would be running from tiller to dock (crew isn't really crew at this point they are ballast, no one that nimble yet except me). Everyone knew this was a ONE-TAKE only bit, but were kept in the loop to know what to expect. The boom/mainsail dropped (controlled), we are on bare poles, coasting the 80 feet. Doing 1.5 knots for my 90 degree turn.
After my 90 degree turn, coasting now at 1 knot, we slid into our dock perfectly, with enough time for me to hop off and stop the boat. It was quick, and less than subtle, but we hit nothing. We collected main/boom, and cleaned up from there once docklines secured.
I would not want to do this every time, but knowing how, and what do expect is part of sailing.
Well done! It sounds to me like you've worked it out.
The key is being able to drop the sail quickly and safely and in picking the right moment to do it. It is a very satisfying thing when you nail it.
This is WAY more difficult as the boats get bigger. We've been forced to do it with our 6000lb 27 footer (dead engine), and you need precision and big arms to stop that beast in the slip. But the J/22 should at least prepare you for what is necessary to do .
Bigger? Not so much - but heavier, yes.
We (and others) regularly sail 3000kg Adams 10's in and out of the dock for the Twilight races - in all conditions (our boat is moored stern-to and requires a 90-degree turn off the main channel) and we carry no engine. Sometimes a tow from someone with an engine is a handy thing to help us get to the start on time, and most are happy to oblige.
After a point it becomes simply too difficult and dangerous to sail in and out of a dock. eg. the +50-foot old gaffers without engines are generally kept on swing moorings instead.
  #15
Old 08-15-2011
RatHatDiver's Avatar
RatHatDiver is on a distinguished road
I'm a green sailor and one thing I have learned around the docks is SLOW IS PRO.
  #16
Old 08-15-2011
Hartley18's Avatar
Termite Fodder
Any mug can roar around quickly - that's why there are so many stinkpots in the world - but sailing slowly, below steerage way, with precision, requires skill.
  #17
Old 08-15-2011
junkrig's Avatar
Both ends are pointy.
junkrig is on a distinguished road
The Chinese operated amazingly large boats with a specially evolved sculling oar. Google "yuloh". It's not docking under sail, but it doesn't stink and roar, either, and is not likely to break down.
S/V Seablossom Nor'Sea 27 with modern junk rig.
Just because I like it.
  #18
Old 08-15-2011
joelsanda's Avatar
joelsanda is on a distinguished road
A couple of trips back I was motoring in and fumbling with the tiller and the engine throttle. These boats (club owned) have the outboards mounted port and it's rather awkward to use the tiller and throttle at the same time.
Between the throttle, tiller, directing the my son and friend, maneuvering into the slip and watching another boat swinging about it dawned on me the engine was more trouble than it was worth. If it died, which these love to do at or above idle, I'd have some explaining to do.
As it was I came in a little too fast and the first line wrapped about a dock cleat was the port stern line. This caused the bow to swing out to the starboard very quickly. Luckily my friend caught that and nothing happened.
But had I come in with oars and/or a reefed main I could have spilled air and cranked the tiller to slow probably faster then throttling down, switching to reverse, and applying gas.
Thanks for the encouragement and stories - next time out willbe maneuvering in tight quarters for practice!
You may post attachments
You may edit your posts
Search Engine Specialized In Sailing franc3 General Discussion (sailing related) 6 03-19-2013 11:10 AM
No Engine Sailing .. thoughts .. jasper General Discussion (sailing related) 115 08-20-2011 12:29 PM
How to know if engine is a fuel injection engine 99miles Gear & Maintenance 4 05-31-2010 10:42 AM
Sailing by Aberdeen Proving grounds I thought at first my engine was about to die! Garffin General Discussion (sailing related) 6 11-11-2009 08:46 PM
Diesel Engine water open while sailing? saurav16 Gear & Maintenance 18 06-25-2007 05:59 AM
SEO by vBSEO 3.6.1
