08-26-2011
Donna's spot on.. most 'furlers' sold nowadays are intended as reefing furlers, but you should try to confirm this as there are many 'old' furlers out there.
There is a loss of efficiency with a partially rolled headsail, but it's really only a serious performance issue if you're beating in a stiff breeze. If you're not racing, and if the furler is appropriate, there should be little downside other than increased wear and tear on the sail (the loads are not supported by the normally reinforced panels at head and tack when rolled)
1984 Fast/Nicholson 345
