I guessing we should've reefed or ? - Page 3 - SailNet Community
 2Likes
post #21 of 34 Old 10-07-2011
SailBerkeley's Avatar
Ideally you would depower the main by reefing as you suggest. But barring that, the next alternative would be to sail jib only.
Sailing Instructor
SailBerkeley is offline
post #22 of 34 Old 10-15-2011
Incline meter
i would suggest two things: more experience and purchasing an inclinometer, preferably one with a micro meter along with a macro meter. Next to a windex, this is, for me, the second most important instrument on board. These meters cost $14 and can be attached with Velcro. Two basic rules, sailboats need to heel at a minimum of 7 degrees to be efficient and they shouldn't really heel more than 30 degrees. In light winds, you may have to induce heel just to get to the minimum and in heavy winds, we all try to reduce incline. The rule in heavy winds: at 25 degree of incline, begin to reduce sail. 15 degree of incline is considered most comfortable. I always give the task of incline monitoring to the person aboard who is least comfortable with heeling. If you don't have one, or are on a boat that doesn't have one, another way of measuring is this: our bodies react to heel automatically. At 15 degrees of incline, one foot automatically reacts by steadying our bodies. At 20 degrees of incline, two feet are needed to stabize our bodies, at 25 degrees of incline, our bodies begin to almost become straight trying to stabilize the effect of heeling.
One other thought: for a sailing novice, I would never suggest using or relying on steering upwind to reduce heel. You are only asking for trouble when the wind shifts or you make a 25 degree steering error. Reduce sail instead, usually taking down the headsail is best, I think. If you are caught with too much sail up, it's better if you don't have to go forward to drop sails. You can then reef the main if needed.
I would also agree with the comment of sinking j24s. Consider that there have been more than 6000 j24s built, and usually raced hard. This boat easily stacks up against any other for flatation stability.
A j22 is a great, full keep boat and should have no problems maintaining stability at any wind level. The repairs in question were/are minor.
My guests comfort is paramount for me.
strictlysail is offline
post #23 of 34 Old 10-15-2011
davidpm's Avatar
I think that sailing unlike many other sports is particularly difficult for spouses to learn together. On a boat someone has to be the captain and sometimes decisions have to be made and actions executed quickly. And to be frank why should she listen to or trust your decision making or skills. You are a newbe and she knows it.
You can continue to go out together on perfect days when there is plenty of time to co-captain and have a great time.
If it is possible you might think about going out by yourself in heavy air whenever possible.
Pushing myself and the boat and at the same time caring for my wife's well being were not goals I could always accomplish on the same sail. So what I did was take her out on all the good days but I still went out on the marginal days by myself. After a few years and some fog, rain, storms and all sorts of major screw-ups on my private sails she eventually got to point where she knows that if I'm taking a boat out I can sail it safely by myself and if she doesn't like what is going on she can go below and not feel guilty or that she is letting me down.
I don't know about your wife but in my wife's case I believe her biggest fear was not really the boat but of not being able to physically do what was needed or doing something wrong.
When she finally got enough confidence in me most of her fears went away.
She still don't like lightning however, apparently my supposed superb sailing skills don't protect us from direct lighting strikes.
And frankly now that I've bashed around a few times in 30k plus I don't like stressing the rig, sails or my bones that much and when I have the chance I skip it.
davidpm is offline
post #24 of 34 Old 10-16-2011
Tartan 27' owner
CalebD's Avatar
All you have to do is a google serach of 'J 24 sinking' and you will get this: Google
Great, fast boats but prone to knock downs.
Everybody has one:
CalebD is offline
post #25 of 34 Old 10-17-2011
You took a racer out on a windy day and that's why you had a hard time of it.
J-22 has sail area / displacement ratio of 24 and weighs 1800lb with a 700lb keel. That puts it in the class of lightweight racer and it's going to need to be reefed earlier (at least if you want to keep the heeling down) than a heavier cruiser. With winds of 12-17 knots, your level of experience, and your SO on board, I'd have been reefing the main from the start.
Does anyone have more of a heavy cruiser you can try chartering? My first time sailing the late (Hunt version) Cal 24 was a revelation after the lighter boats - stiff, stable, predictable, sea-kindly. Just what you need to get your SO some confidence.
An important skill is heaving to so you can have a break, reef, a sandwich, whatever.
MarkSF is offline
post #26 of 34 Old 10-17-2011
Originally Posted by anthemj24 View Post
The same could be said about the Santana 20, however you never seem to drag that into a thread.
From the Santana 20 class website
I am not at all defensive about J24s, but I will be vocal if someone is exaggerating the issues with the boat. It is not difficult to handle in heavy wind, and the sinking issue is solved be simply latching the cockpit lazarettes. If your intent is to be helpful, then you ought to include that simple bit of information on how to avoid sinking.
Does sound defensive to me. It would be churlish not to recognise that there are cruising sailboats and racing ones with different priorities. The J boats tend to fall into the latter category and are thus harder to sail in high winds than the former. I think that's the point Mr. Schock was making.
MarkSF is offline
post #27 of 34 Old 10-17-2011
davidpm's Avatar
Great idea I chartered a Hunter 33 a few months ago in Pensacola FL. We sail a Catalina 25 here in Long Island Sound.
She steered the Hunter almost the whole time even in 25 knots and was very proud of herself that she wasn't bothered at all.
The boat makes a really big difference.
What was interesting is that at first she was very leery of steering the bigger boat but after just a couple of hours she found it much easier to control since it had a wheel and everything was so much slower.
So now she likes the idea of a much bigger boat, Sigh!!
davidpm is offline
post #28 of 34 Old 10-17-2011
Water Lover
Location: New Mexico, USA (Heron, Elephant Butte lakes); Arizona (Lake Pleasant)
Race boats like the J/22 and J/24 in strong breeze are designed to have an adequate crew actively hiking. Without that rail weight, and with a nervous significant other on board, reducing sail area has do be done much sooner than when in racing mode. One question that probably should be asked, given that this particular J/22 had sail controls in poor condition:
Was this particular boat set up for reefing? Some racing sails don't even have reef points. If a boat's sails aren't set up for reefing, then it would not be the best choice for a nervous beginner. And, with a hanked-on genoa or jib and a curved foredeck without a rail to provide confidence, I don't think your spouse would have polite words for you if you asked her to go forward to douse the headsail. And she might be just as nervous about you going forward and leaving her alone in control of the "monster".
PS, the concern about J/24s sinking seems partly based on older J/24s with cockpit locker doors that weren't secured, driven hard in race mode in heavy air (spinnaker wipeouts with an inattentive crew etc.). If you make sure that your boat has latchable lockers doors that secure properly, that will be good for peace of mind. Now, I think that if Bill had really meant to trash talk the 24s, he would have brought up the vermiculite... but now we're drifting well off course.
Oh, and if you really want your spouse to hate you, try teaching yourself aggressive spinnaker maneuvers in 20 knots while sailing short-handed (without a talented full-sized crew approaching the 275 kg/605 lb. J/22 class limit). It can be spectacular!
rgscpat is offline
post #29 of 34 Old 10-18-2011
I have been in this exact situation. Panicking seasick wife, learning to sail under heavy air, J24 heeling to much for comfort. I did reef though, I couldn't find anything on the boat that looked like reefing gear, so I finally used the sailties by tying them together end to end from the reefpoint to the outhaul cleat. It worked and made the boat much more manageble, even though I didn't have perfect sail shape.
The Admiral insisted we go back early anyway.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #30 of 34 Old 10-19-2011
The time to reef is at the moment that you think it might be time to reef. If you are inexperienced (or your passengers or crew are inexperienced), reef early. Additionally if you are in heavy winds where the rudder is exposed, reefing will make the boat handle better and alloow you to sail faster. The boat wont be over powered and over heeled. Everyone will have a better time.
s/v Odyssey
Catalina 30
glassdad is offline
Depowering sails - when reefed main and smallest jib aren't enough, what next? Stearmandriver Learning to Sail 62 04-21-2011 02:09 PM
Flattening Reefed Mainsail, or why no Cunningham? NCC320 General Discussion (sailing related) 10 11-15-2010 04:52 PM
Foot of main when reefed? jaschrumpf Learning to Sail 12 09-10-2010 12:39 PM
