10-10-2011
"Stupid Human trick":
Hold your clenched fist, thumb on top, at arm's length.
Your fist, from little finger to thumb, describes an arc of ten degrees.
So each knuckle is two degrees.
Sun etc move 15 degrees per hour, so one 'fist' is 10/15th hour, or 40 minutes' worth of celestial movement. And each knuckle is 8 minutes.
Now you have a quick way of telling how long til sunset. Or, if you rotate your fist to measure laterally, how many degrees that other guy is off your bow.
