-   Learning to Sail (http://www.sailnet.com/forums/learning-sail/)
-   -   Points of Sail...is this right??? (http://www.sailnet.com/forums/learning-sail/79364-points-sail-right.html)
NewportNewbie 10-01-2011 11:49 PM
Most Points of sail diagrams I have see are like circles and have the wind coming from one direction while the boat moves around it. Thats backwards to me because I want to have the boat pointed in one direction and have the wind move around in relation to the boat. I also want to add the windex on the mast into the equation in relationship to the beam. I wanted to see if there was any correlation between the angle of the windex and the angle of the beam, a quick way to determine the reach. I am very good at close hauled, seems to be the easiest, its when I am reaching that I am in a not sure zone. So I made this diagram to show the relationship between the wind and the windex and the beam and jib...is this correct?
http://web.me.com/jrhone/docs/pos.jpg
PaulinVictoria 10-02-2011 12:01 AM
Not quite. Your beam reach is actually a close reach, and your broad reach is a beam reach.
NewportNewbie 10-02-2011 12:11 AM
really? the diagrams I am looking at don't show a close reach at all...
http://0.tqn.com/d/sailing/1/0/d/0/-...ailDiagram.jpg
NewportNewbie 10-02-2011 12:13 AM
found another one....yes....I see....its in there...the ones I saw were simplified....
http://bsaseabase.org/filestore/seab...ts_of_sail.jpg
HPLou 10-02-2011 08:05 AM
It should be noted on your diagram that the wind direction as shown is the apparent wind direction as it relates to the same angle as the windex. The true wind direction would usually be at a slightly different angle than the apparent wind direction. In other words, the apparent wind direction would be the resultant vector of the true wind direction and the boat direction.
SHNOOL 10-02-2011 06:18 PM
Note also some others will replace "beam reach" with just "reach."
Take special note of HPLou's reference to "apparent wind." Apparent wind can make or break a sailor. Knowing true wind direction, and apparent wind direction (which is the direction wind "appears" to come from due to your own velocity moving forward), can help you determine the "best line to a mark."
In light wind any forward momentum you have while entering a wind shadow can cause you to chase your windex around a circle. Also using ApWind technique you can keep your sails filled and "point higher" while coasting through a wind shadow. All depends on that Apparent Wind direction.
tempest 10-02-2011 07:24 PM
Newport,
If you tie some wool tell tales on your shrouds port and starboard the middle one maybe; it will help you see the apparent wind angle.
Close hauled your tell tale will be pointing toward the leech of the mainsail,
Close reach it will point more toward the center of the mainsail ,
Beam reach it will point to the mast,
Broad reach it will point to the Jib/genoa.
Run will be pointing toward the bow
This is pretty simplistic, but I have found that it helps when I try to explain points of sail.
Faster 10-02-2011 07:28 PM
Originally Posted by Tempest (Post 781919)
Newport,
If you tie some wool tell tales on your shrouds port and starboard ...
Or dig into your closet/basement and find that old ABBA cassette tape;)... rip some of that out and use it as you would wool... lighter, and less affected by rain (but more fragile)
WDS123 10-03-2011 12:00 AM
Cassette tape works very well
8 track even better
T37Chef 10-03-2011 12:13 AM
8 track even better
You're really dating yourself there :D
