Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 10-25-2011
gabrielbunda is on a distinguished road
When should I..
Hi there!
Guys, when should I use a gennoa and a spinnaker/gennaker at the same time?
Ty!
Old 10-25-2011
celenoglu's Avatar
celenoglu is on a distinguished road
If you are already flying a kite, using a genoa at the same time will decrease the amount of wind on your spinnaker, which means decrease of power and speed.
Another time to use both is when you are changing from one to the other.
Old 10-25-2011
nolatom will become famous soon enough
Not the genoa, it's too big. Especially with an assymetrical spinny.
But a working jib? yeah, on a beam reach in light air, or a fairly tight broad reach in moderate air. That's when you still have "sideways" airflow over your sails and the jib can 'fit into' some air the spinny isn't using. Any lower than that and it's "push" air, jib won't help and may hurt.
Old 10-27-2011
MarkSF is on a distinguished road
Welcome to the forum.
When titling a thread, try to consider that one day someone may be searching for that subject.
"when should I" will not help very much.
"genoa and spinnaker at the same time" would be much better.
Bristol 31.1
Old 10-28-2011
WDS123 is on a distinguished road
It depends:
On rig - some boats can fly a chute and foresail at same time, rare design but happens
On angle - wider angles may allow you to have both sail up, the genoa will tend to flop around uselessly
on pressure - lighter air usually needs as efficient sails as possible, the foresail tends to spoil the airflow around a kite. Heavier air one might want to depower the kite.
