Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #11
Old 11-07-2011
nolatom will become famous soon enough
Do you know if it's adjustable, or are you asking us (?) I can't tell from how you describe it.
What you want is for it to be just slightly slack when you have the mainsheet cranked in as hard as you would for sailing upwind, or as hard as you would ever crank your vang down. When sailing (except maybe in really light air as mentioned, but maybe not even then) you want the leech of the main to take the weight of the boom and the pull of the mainsheet, not the topping lift.
If there's no adjustment, then add one on, or a shackle or two, until it's just slack enough.
  #12
Old 11-07-2011
pogosmoke is on a distinguished road
Ok Ill give it a look next time im at the boat and take some pics. Thanks!
  #13
Old 11-07-2011
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
pogo
I am not sure I am reading your OP correct but the idea of a cable topping lift sounds off to me. If it is not line(rope) from front to back, I would suggest it be replaced.
A few thoughts on this;
- The replacement line can be quite light as all it has to do is hold the boom up when not sailing.
- Make the replacement line the same dia as your halyard that way it can be multipurpose.
- Use the opportunity to replace a worn/old halyard and use the old line as your topping lift.
John
  #14
Old 11-07-2011
leogallant's Avatar
leogallant is on a distinguished road
Ahh! Now, I know what that is! Thanks for asking the question. I was wondering why I couldn't tighten the vang for better sail shape! Glad you knew what to ask :-)
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
  #15
Old 11-09-2011
Haven't been back to the boat yet but I took this pic the other day this cable is the line I'm talking about.
  #16
Old 11-09-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Yep. That is called a topping lift and it holds the boom up.
The picture is good because it shows a length of doubled back line(rope) at the bottom that is evidently used for adjusting the tension in your topping lift. I doubt you have an adjustment for this line at the bottom of your mast (like a halyard) as it is a fairly primitive set up. OTOH maybe you do. If not you need to start loosening that section of line(rope) at the bottom of the topping lift once you raise the main sail and then re-tension it once you bring the sail down.
Everybody has one:
  #17
Old 11-10-2011
Yeah, slack it about 6 inches(?) and see if the batten tips don't free up and fall off to leeward. That should take care of the chafe problem. When you sheet the main in fairly hard, the topping lift should be just barely slack. So that may take a little further adjustment.
Looks like an eminently solvable deal, let us know how it goes.
  #18
Old 11-10-2011
carl762's Avatar
Sundance 23
carl762 is on a distinguished road
I undo mine, when the sail is up, and then attach the topping lift to the backstay until it's time to lower the sail.
Water is Life
  #19
Old 11-13-2011
Charlie B's Avatar
Charlie B is on a distinguished road
My present boat just has a pig tail on the back stay, so I have no choice but to unhook it. But on my last boat, I always unhooked the topping lift. Why leave it flopping around? I would just clip it to the back stay and it never caused me any trouble. If I forgot, the sail wouldn't hang right and looked ridiculous.
1968 Morgan 24/25 S/V My Fair Leslie
  #20
Old 11-14-2011
casey1999 is on a distinguished road
With my main up, the boom will hit my dodger. Seems PO used the topping lift to keep boom from rubbing dodger. Does this mean the main sail is too long in the leach and luff? With the boom horozontal- it only clears the dogger by 6 inches. The doger is fixed and cannot be lowered.
You may post attachments
You may edit your posts
head troubles...... twisted23 Gear & Maintenance 21 10-14-2010 09:22 AM
Maxsea and USB GPS troubles FollySailor Gear & Maintenance 2 07-08-2010 07:11 AM
overcoming some VHF and GPS troubles CaptainRonandAshley2 General Discussion (sailing related) 1 08-27-2008 04:38 AM
More 12v Troubles and ?'s Perithead Gear & Maintenance 7 11-26-2007 12:33 PM
Dumb Mainsail question dmelroy Gear & Maintenance 3 06-16-2006 01:26 PM
SEO by vBSEO 3.6.1
