12-06-2011
Originally Posted by smurphny
SF may have a good idea about making a new mainsail. The sail you have could even be recut. If the boat is a modern design, predominantly headsail powered, a few feet missing from the lower part of the mainsail will probably not make much difference. It would likely result in better performance since you wouldn't have to worry about pulling the gooseneck down with downhaul tension. Having the right tension along the luff makes a LOT of difference in performance when you're close hauled.
I would check the design specs. of the sail system first to determine if the existing sail is the right one. You may discover that the sail is not the right sail in the first place. Which came first, the dodger or the sail?
The dodger frame has been on the boat since first built (1978). The sail was made by Horizon Sails Austrailia- seems this company is no longer in buisness- I have e-mailed and get no response and there web site does not open. This main is about 5 years old but has one 3 year circumnavigation on her by PO so has a lot of UV damage.
