Wing on Wing - SailNet Community
 7Likes
post #1 of 25 Old 03-22-2012 Thread Starter
BreakAwayFL's Avatar
Wing on Wing
Can I sail wing on wing without a whisker pole? If so, is there anything I should know? I may be trying ti on Sunday.
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
BreakAwayFL is offline
post #2 of 25 Old 03-22-2012
bljones's Avatar
Re: Wing on Wing
Absolutely,
It's 5 o'clock somewhere:
bljones is offline
post #3 of 25 Old 03-22-2012
remetau's Avatar
Re: Wing on Wing
We found that in choppy water or shifting winds the jib will usually collapse and refill sometimes with a lot of force, but yes very doable especially in lighter winds.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #4 of 25 Old 03-22-2012
jackdale's Avatar
Re: Wing on Wing
I have flown a gennaker wing on wing with no pole.
The pole can help
You might want to use a preventer, rigged from the boom end to the foredeck and back.
Watch the wind carefully.
If the boat starts to wallow just hold the wheel and wait for it to settle down. Trying to counteract the wallow can exacerbate it.
Gybing the main is a little easier than gybing the foresail.
Get onto a starboard tack (main to port) to maintain some stand-on privileges.
jackdale is offline
post #5 of 25 Old 03-22-2012 Thread Starter
Re: Wing on Wing
um... what's a preventer?
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
post #6 of 25 Old 03-22-2012
Senior Smart Aleck
jameswilson29's Avatar
Re: Wing on Wing
A line rigged from the boom to the leeward rail to prevent a jibe.
If you have a boom vang with a snap shackle, you can remove it from its attachment point on the mast and attach it to the leeward toerail or a leeward stanchion base.
If you try to run wing and wing without a pole, you probably want to overtrim the mainsail so it spills wind into the jib and keeps it out.
jameswilson29 is offline
post #7 of 25 Old 03-22-2012
jackdale's Avatar
Re: Wing on Wing
It prevents an accident gybe.
Attach a very lone line to the boom end(with a shackle), feed it to block on the foredeck (outside of the shrouds) and bring it back to a cockpit winch or cleat.. In case of an accident gybe the boom will not go flying over the cockpit. You will be able to ease the main over.
A boom brake would also work well - maybe better as t slows the gybe down.
DO NOT USE YOUR BOOM VANG AS A PREVENTER.
Faster likes this.
jackdale is offline
post #8 of 25 Old 03-22-2012
Senior Smart Aleck
Re: Wing on Wing
Why not use (a non-rigid) boom vang as a preventer? Not only does it prevent a jibe, it can continue to function as a boom vang on the rail.
post #9 of 25 Old 03-22-2012
celenoglu's Avatar
Re: Wing on Wing
Keep your main to windward and genova to the other side.Be very careful with the movements of the boat with waves.
celenoglu is offline
post #10 of 25 Old 03-22-2012
Re: Wing on Wing
Amen....
Sailing wing-on-wing sans pole usually works best by sailing slightly by-the-lee.. this tends to direct the AW in a direction that tends to hold the jib out.
Problem is, of course, that you're almost always on the verge of an accidental gybe.. so there's no relaxing on that score.
Wing on wing is really my least favourite setup.. and why I prefer a manageable symmetrical spinnaker for deep downwind work.
chef2sail and jackdale like this.
Faster is offline
Wing on wing zfactor Learning to Sail 50 06-02-2014 08:17 PM
What is a wing sail and why aren't they many of them? jbarros General Discussion (sailing related) 12 11-25-2009 11:36 AM
Wing on Wing, disconnecting the Whisker pole L124C Seamanship & Navigation 15 10-25-2009 02:05 AM
Wing & wing using staysail? Ilenart General Discussion (sailing related) 9 08-20-2008 01:27 PM
Wing to Wing How? 1970Columbia34 Learning to Sail 26 05-25-2007 07:38 PM
