How do you sail a cat? - SailNet Community
post #1 of 4 Old 04-09-2012 Thread Starter
How do you retrieve a man overboard in a cat and how do you right a cat?
Hurricane5.9
Hurricane5.9 is offline
post #2 of 4 Old 04-09-2012
One of None
deniseO30's Avatar
Re: How do you sail a cat?
How do you sail a cat? fast! I've never sailed a cat so my advice is just words on the screen
I think some racers use mast floats. righting is done by getting the crew wet of course, and I think using your weight with the weight of others to bring the dry pontoon back down to the surface. Big cats.. big problem I'd say. MOB depower the sails come about and tack back to the victim. you should have rescure equipment on board. It looks to me like smaller cats are like sailing smaller keel boats, PLAN on getting wet.
fun to watch
My last project!
deniseO30 is offline
post #3 of 4 Old 04-19-2012
Sailing Member
Hurricane5.9
I think righting a cat is one the easier boats to right. We have a Hobie 16 and we have had to right it many a time because we like to fly a hull whenever we can! The best product we have found is a righting line. Our friend here in Utah makes them and then sells them on Ebay. We did a short video and blog post about it, here's the link to see it. In the video we show how we right our Hobie.
Hobie Sailing Gear-Righting Line
Hope that helps.
Terry
getwet is offline
post #4 of 4 Old 06-01-2012
casey1999's Avatar
Hurricane5.9
I used to sail a Prindle 16 on Chesapeake Bay. I once was sailing with a friend who went overboard at the mouth of the Severn river. I turned the boat around and headed toward him and as I got near him aimed the boat right into the wind and stopped so that he could climb (and me drag him aboard). It was a little dicey.
I would sail the boat alone and on ocasion flip it over. The key is to have a righting line that is tied to the base of the mast and long enough that you can toss it over the upper hull (the mast lying horozontal), then hike out while pulling the righting line to put the boat over (righting line should be very large diameter say 3/4 inch and with knots so you can grip. It will help to have the bows pointed into the wind so that the wind helps to lift the sail/mast (wing effect) and once you get the boat up, the sails will be luffing (before righting the boat uncleat the main and jib so the boat will not sail off without you). It is quite a handfull to upright a hobie or prindle 16 alone and if it is windy very difficult. If the boat goes turtle, you will not be able to right it (that is why it is criticall to right the boat ASAP sot that the mast does no go below water, I have seen some mast tips have a float to prevent this). Also, once water gets on the sail, it becomes difficult to right.
Couple things to keep in mind, when righting the boat, you may need to dive under the water to prevent getting hit on the head by the falling pontoon. Also, at times once righted in heavy wind and sea, with no one on the boat can easily flip again, you need to jump immediately back on the boat, and hold onto the boat so it does not sail off with out you.
I once was windsufing in 25k and saw a guy sailing a hobbie 16, he had turned over. I helped him get the boat upright, but soon after he flipped again, the boat went turtle and he had to be towed by marine police.
casey1999 is offline
Sailor fishing for victory at XXXX Sail Paradise 2012 - Sail World NewsReader News Feeds 0 03-23-2012 12:40 AM
The Club Marine Sail Boat Show this weekend - Sail World NewsReader News Feeds 0 03-22-2007 06:15 PM
Melbourne Club Marine Sail Boat Show - Sail World NewsReader News Feeds 0 03-18-2007 06:15 PM
The Voyages of the Good Ship Jabulani: Finally under sail @ Sail Blogs NewsReader News Feeds 0 04-18-2006 03:15 PM
Sydney Yachts at Strictly Sail Pacific @ Sail World Australia NewsReader News Feeds 0 04-17-2006 08:15 PM
