Roller reefing - Page 2 - SailNet Community
 1Likes
post #11 of 24 Old 06-11-2012 Thread Starter
Roller reefing
Ok. I'm out tonight so I'll check my halyard tension and I'll have a spare set if hands to keep a good tension on the line as I unfurl the sail.
I'm already a member of the M24 group on yahoo - I've had a few emails into that group to
address boat specific issues.
Loving the boat so far. Small enough to single hand (or manage with my kids) but big enough to feel like a real boat (as compared to my old dinghy racing days). PO left me with great sails which helps - but in modest winds I'm easily clearing 6kts into the wind. Haven't had a chance to run a windy beam reach to see how fast she will go.
mgb69 is offline
post #12 of 24 Old 06-11-2012
Re: Roller reefing
I had a problem with my furler couple of years ago, found out that the swivel needs to be greased and I haven't done it. The swivel frozed and I had to buy a new one.
phoxie is offline
post #13 of 24 Old 06-11-2012
Re: Roller reefing
Also, if you tighten you back stay and take some of the sway out of the furler it will turn significantly easier.
Mark1948 is offline
post #14 of 24 Old 06-11-2012
Re: Roller reefing
At the risk of asking the obvious, you are not trying to reef with the sail sheeted in and drawing, are you? If you head up or release the sheet such that the sail is almost luffing, you should be able to pull in the furling line by hand.
meteuz is offline
post #15 of 24 Old 06-11-2012 Thread Starter
Roller reefing
Good sail tonight.
Made a point of keeping some tension on the reefing line as I pulled out the jib.
Was able to hand furl the job at the end. Still stiffer than I'd like - but to bad.
I'll look into lubrication and halyard tension soon. Might make it that much easier.
Of course there are always new issues - tonight my trusty and recently serviced outboard decided to pack it in 500m off dock. Had to sail it in. Winds were light and perfectly angle for an easy docking on the outer rim - but not the challenge I was hoping for!
Thx for all the advice. Little more work I'll have that part sorted and ready to tackle the next.
Mark
mgb69 is offline
post #16 of 24 Old 06-12-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Roller reefing
Originally Posted by mgb69 View Post
...tonight my trusty and recently serviced outboard decided to pack it in 500m off dock. Had to sail it in...
Good job! It's always something isn't it? My OB did the same thing to me while transiting from the launching marina to my mooring this spring. I just recently heard that I should leave the main up until I moor just in case the iron wind dies. That makes sense, but to have it up for the hour plus transit up from the mouth of the river, flopping around and spoiling my view...
We'll see.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #17 of 24 Old 06-13-2012
Seņor Member
ottos's Avatar
Re: Roller reefing
... Can't imagine how I could reef in heavy weather. ...
Mark
The general rule applies - especially in this case. "Reef when you first wonder if you should!"
ottos is offline
post #18 of 24 Old 06-13-2012
Re: Roller reefing
Is the reefing line big enough (dia) to fill the drum when sail is set? I found that the bigger torque helps start the furl. My gennie is pretty big (500 sq ft)and needs help and good timing.
Capt Len is offline
post #19 of 24 Old 06-13-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Roller reefing
As others have noted, the two biggest culprits are getting the halyard wrapped and not having enough tension on the forestay. The installation specs. as to angle of halyard line where it exits the block to the top swivel are quite precise. If there is a noticeable sag in the foil it will make turning the drum difficult to impossible. Drum binding seems to be somewhat unavoidable but tension must be maintained rolling in and out. I keep sheet in one hand, furler line in the other to maintain control.
smurphny is offline
post #20 of 24 Old 06-19-2012 Thread Starter
Roller reefing
Thanks for all the advice.
By keeping tension on my furling line as I pull out the jib I've been able to re-furl fairly easily.
Tension on backstay seems good and the furling line is running cleanly to the block.
I will make a point of dismantling and lubricating the furler in the fall.
Thx
Mark
mgb69 is offline
Frozen roller-reefing boom spin1012 Gear & Maintenance 4 06-20-2010 08:15 AM
Roller Reefing Question... MedSailor Gear & Maintenance 2 06-17-2010 09:05 AM
Plastimo Roller Reefing Problem BeneteauFirst24 Gear & Maintenance 2 05-21-2009 08:27 AM
How to tension forestay with roller reefing? wysiwyg Gear & Maintenance 17 06-14-2007 12:09 PM
Behind mast roller reefing wcshedd Gear & Maintenance 7 12-31-2003 08:47 AM
