Go Back   SailNet Community > General Interest Forums > Learning to Sail
Like Tree1Likes
  #21
Old 06-19-2012
ccriders is on a distinguished road
Re: Roller reefing
In the interim, hose it down with fresh water, lots of it.
  #22
Old 06-19-2012
Pirate Chief
Paddyd is on a distinguished road
Re: Roller reefing
take it apart walk away for a day
then review it again
check lines and how the run thru the blocks
check your lines for chafing particles caught iniside
  #23
Old 08-11-2012
seabee is on a distinguished road
Re: Roller reefing
i have been at this for 45 years now and the first thing I would ck is to make sure you have enough tension on the head shroud, any amount of curve in this shroud, will make reefing very tuff. even in light air. and rotating it by hand is easy but very tuff if it has any curve in it while reefing (straight foil curved shroud does not furl well. Next i would make sure that the furling line is at the proper angle out of the drum (90deg) and last I would ck to see if you have enough angle of the halyard out of the mast to top swivel, not enough angle will stop top swivel from turning. And last but not least make sure you tighten the halyard before trying to furl. May your sails always be full and the sun on yur back---SEABEE
  #24
Old 08-20-2012
randy capedory 25d seraph
rtbates is on a distinguished road
Re: Roller reefing
when was the last time the system was maintained? Lubed? Cleaned?
FRICTION is your number one enemy
You may post attachments
You may edit your posts
Frozen roller-reefing boom spin1012 Gear & Maintenance 4 06-20-2010 08:15 AM
Roller Reefing Question... MedSailor Gear & Maintenance 2 06-17-2010 09:05 AM
Plastimo Roller Reefing Problem BeneteauFirst24 Gear & Maintenance 2 05-21-2009 08:27 AM
How to tension forestay with roller reefing? wysiwyg Gear & Maintenance 17 06-14-2007 12:09 PM
Behind mast roller reefing wcshedd Gear & Maintenance 7 12-31-2003 08:47 AM
SEO by vBSEO 3.6.1
