Jib trimmed but main luffing? - SailNet Community
 2Likes
post #1 of 13 Old 06-18-2012 Thread Starter
I was out for a great sail yesterday, winds around 13 knots. It was also my first sail with "company" (other than the admiral) on board, so I was a little nervous and didn't want to look incompetent to my non-sailing guests. O
n my first few tacks I sheeted in the jib tight, but when the jib telltales were flying perfectly the main (sheeted tight over centerline, traveller in the middle) would luff. What would cause this? I'm thinking that the jib was sheeted in too tight and the main couldn't go any tighter, or that the jib can be set closer to the wind than the main, but I'm really not sure if this is the correct or logical explanation.
On subsequent tacks, I just let the jib out a little and the main would fly fine. We were pointing fine and had good speed, but I'd still like to know if there was something I could have done differently.
Skipper Chris
cdhickey is offline
post #2 of 13 Old 06-18-2012
72 C&C Corvette
CorvetteGuy's Avatar
Re: Jib trimmed but main luffing?
Do you have a leach line on the luff of the sail? if so try tighting it up some.
CorvetteGuy is offline
post #3 of 13 Old 06-18-2012
When you say that the main was sheeted over the center line...traveler to the center.
Does that mean that the boom was centered? If not, you could try moving the traveler to windward a bit.
tempest is offline
post #4 of 13 Old 06-18-2012 Thread Starter
Sorry- the boom was as close to center as I could get it with the traveler in the middle.
There is no leach line on my main and my topping lift was fully eased.
Skipper Chris
cdhickey is offline
post #5 of 13 Old 06-18-2012
Junior member, rest old
msmith10's Avatar
As Tempest commented earlier- move your traveler to windward. You don't need to stop it at the centerline.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #6 of 13 Old 06-18-2012
ASA and PSIA Instructor
If you are sailing with an overlapping jib, as the breeze comes on you will experience some backwinding on the main...all the air volume trying to squeeze through the slot between the jib leech and the main luff can't fit, so some of it flattens the luff of the main.
This is OK, you cannot trim backwinding away, and definitely dont take the traveller up in a breeze! when sailing closehauled like this, the jib is powering the boat, the main is just helping your balance and pointing, dont worry about the backwinding.
sailingfool is offline
post #7 of 13 Old 06-18-2012
What sailingfool said. You've got the backwind bubble going on.
puddinlegs is offline
post #8 of 13 Old 06-18-2012
asdf38's Avatar
I'd be careful about trying to point to high. There is a point of diminishing returns, just because you can point a few degrees higher doesn't mean that's the best way to move upwind. At some point you'll lose speed at which point you'll start making more leeway in the water. If you've got the boom pulled all the way in (inboard of the rails) and it's still luffing I would think you'd want to let the jib out.
asdf38 is offline
post #9 of 13 Old 06-18-2012
nickmerc's Avatar
My P30 sails much better when the "luff bubble" is present while pointing (150% genoa). The helm is very well balanced and leeway is minimized. It took me a whole season to figure that one out.
nickmerc is offline
post #10 of 13 Old 06-18-2012
jackdale's Avatar
Many boats are like that. When trimming I use the mainsheet to get the right twist, then adjust the traveler until there is a slight amount a luffing. That usually means moving the car windward. A good guideline is that when close hauled, the boom should be on the centre line. Your knotmeter will let you know if your trimming is effective.
jackdale is offline
If it's not luffing, it's helping? steveg353 General Discussion (sailing related) 8 03-11-2012 07:33 PM
Rights and luffing sails jarcher Racing 13 08-25-2009 08:04 AM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 05:26 AM
luffing the leech ... mikehoyt Racing 10 08-11-2006 01:16 AM
Rules - Luffing v Sailing above proper course Bootydawg Racing 2 09-09-2005 08:15 AM
