Go Back   SailNet Community > General Interest Forums > Learning to Sail
Like Tree3Likes
  #31
Old 10-07-2012
DonScribner is on a distinguished road
Re: Docking with an outboard
We often dock on the Saco River, at a nice launch facility called Marblehead, tha sticks out from the bank, perpendicular to the flow. We have to motor up river int a 3-4 knot current (guessing). It takes about 1/3 throttle to hover, which I often have to do, waiting for those dreaded stink-potters to make room for elegance (getting deep). I'll hover and inch towards then end of the dock. About 1 1/2 boat lengths away, I pass by about a boat length then steel about 45 degrees to port. The current takes over and gently lays us against the dock. I often have to play the throttle and steer with both the tiller and the motor, at the same time, to keep us on course.
davidpm likes this.
  #32
Old 10-08-2012
dlandersson is on a distinguished road
That pretty much what I do also.
Originally Posted by Sublime View Post
That's how I do things. Coast in while in neutral and use the rudder.
  #33
Old 10-08-2012
arknoah's Avatar
s/v Ilya
arknoah is on a distinguished road
Originally Posted by talyn1 View Post
I have a 6hp nissan mounted on the back of my Coronado 23 MkII. I am interested in hearing other peoples methods of docking and how they switch between their tiller and motor controls. I feel like my outboard demands a frustrating amount of attention as I am docking and maybe some of you fine folks out there have a method that will make the end of my trips a little easier on me and my wife. Thanks in advance.
I tend to use the tiller and outboard together. Using just the tiller doesn't give me a tight enough angle in my marina. Over just a few times, I've gotten reversing into the slip down to a science.
Ilya's Adventures:
____________________________
And straight on 'til morning
  #34
Old 10-09-2012
patroeski is on a distinguished road
Very helpfull thread
  #35
Old 11-06-2012
carl762's Avatar
Sundance 23
carl762 is on a distinguished road
Indeed. One of the scariest things I do on the boat. Have to lean 2/3 of my body through the rail just to access the shift lever. Not fun. I do keep the motor straight and use the rudder once I get up speed.
Water is Life
  #36
Old 11-10-2012
biology's Avatar
biology is on a distinguished road
this post is slowing down... but I'll just mention that I typically keep the motor straight and use the rudder.
The other thing to bear in mind with some smaller outboards is that they don't have reverse (such as a 2-stroke 4 hp). Those can usually spin 180 degrees for "reverse" which actually doesn't work too bad. I've used one of those quite a few times easing in and out of slips with a 27' while the 8hp was getting tuned up.
I think the main thing is planning ahead for your approach and trajectory and don't rush. I know my boat won't really be quickly stopped by reverse with the motors I've had on it, so I go just fast enough to maintain steering, then coast into the slip. And never be afraid to abort your approach and swing around if necessary to improve your angle or speed. I've had to do that in heavy winds and after making a couple adjusted approaches feel better about sliding in as smooth as a calm day than bouncing around between pylons just to get it in there...
If you are worried about bouncing around, string a couple strategic fenders to protect from dock corners or pylons. You can also run a taught rope between your slip and the adjacent (if it's the open style with only a walkway on one side) between the dock and pylon. You might do that anyway if you're worried about your neighbor bouncing off of you!
Once you feel comfortable it's fun!
Ex Scientia et Artes Vita
  #37
Old 11-12-2012
biology's Avatar
This useless thing will soak up far more of your time than it should... it's oddly addicting.
control with arrow keys. Increase the wind and current for an additional challenge once you've gotten it in the slip successfully.
PCC - Michael Trigoboff - Docking Simulator
You may post attachments
You may edit your posts
Docking with two welshwind SailNet FAQ's 15 09-21-2011 10:56 AM
Docking jitters rickanlisa Learning to Sail 11 09-16-2009 11:26 AM
When Docking, Easy Does It Bruce Caldwell Seamanship Articles 0 08-16-2004 08:00 PM
When Docking, Easy Does It Bruce Caldwell Gear and Maintenance Articles 0 08-16-2004 08:00 PM
Docking Jeffamc General Discussion (sailing related) 11 09-20-2003 09:05 AM
SEO by vBSEO 3.6.1
