roller plotter or parallel rulers? - Page 2 - SailNet Community
 1Likes
post #11 of 26 Old 09-22-2012
jackdale's Avatar
Re: roller plotter or parallel rulers?
Portland plotter
jackdale is offline
post #12 of 26 Old 09-22-2012
I use two triangles but my fav tool is simply a see through protractor that is big. One can line it up with north and measure angles fairly well. Measure the bearing to your "aid to nav" and then put that angle on the icon on your chart. You are then along a line passing thru the center of the protractor (after correcting for local variation). Do it again for a 2nd aid and the intersection is your position. My fav compass is a simple Silva compass with a fold-up mirror. It is light, easy to use and for me, intuitive.
A large right triangle of clear plastic is truly valueable to go from Lat and Lon alomng the chart sides to your place on the chart.
Frogwatch is offline
post #13 of 26 Old 09-22-2012
A roller plotter and a long straight edge works well.
I have a big chart table, however.
Rockter is offline
post #14 of 26 Old 09-22-2012
Wish I never found SN!
SimonV's Avatar
I have both and use neither very often, To the folks at OpenCPN thank you.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #15 of 26 Old 09-26-2012 Thread Starter
Gin Swilling Yacht Monkey
well, still learning, but now having done some plotting at sea, parallel rulers are theoretically the most intuitive, and work great in a classroom but when the boat is on its ear are not so friendly.
portland plotter is the winner so far, but i have to do some real self study at home to find out if there is anything they dont do. i havent tried the two triangles or the roller plotter yet. Oh, and for the boats i have been using, sailboats 40' and under, the smaller tools fit the nav table better.
i guess it's time to take a coastal nav course.
my bet is that the portland plotter is going to hold it own pretty well.
groggy is offline
post #16 of 26 Old 09-26-2012
Senior Slacker
SlowButSteady's Avatar
Two triangles --- K.I.S.S.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #17 of 26 Old 09-26-2012
I find the Davis One Arm Protractor easiest to use-- particularly, when at the helm I'm working with a chartbook in my lap. Parallel rulers, roller plotter, and a pair of triangles all require a flat surface.
Hudsonian is offline
post #18 of 26 Old 09-26-2012
jackdale's Avatar
and ideally charts without any creases or folds.
I have a Davis plotter as well. I like the sturdy construction of the Portland plotter and the ability of account for variation. I have some instructions that show how to account for deviation as well, but since none of the boats I sail have deviation cards, I have not tried out that feature.
The parallel rule is nice for doing a faster advanced LOP. But I am almost as fast with the Portland.
My next best "plotter" is the Douglas protractor. Not mentioned yet.
jackdale is offline
post #19 of 26 Old 10-19-2012
Capt Nery
nmejicano's Avatar
The problem with both rolling plotters and parallel rules is that in a moving boat, they tend to slide. A minor slide and you screw up your plotting. My solution (not patented yet) is to use a rolling plotter, I use an inexpensive Weems & Plath. They have two small grooves between the rollers. Go to Home Depot, and buy the smallest o ring that will fit snuggle in those grooves. Now you have a roller that stick to the chart. Good luck
nmejicano is offline
post #20 of 26 Old 10-29-2012
Halcyon1's Avatar
I use a Portland Plotter which I personally think are most suitable for smaller boats.
Pete
Halcyon Yachts - International Yacht Delivery
Halcyon1 is offline
Two Batteries in Parallel jrophoff Electrical Systems 18 04-23-2012 10:04 AM
BMV600, EchoCharger and two 12v in parallel rikhall Electrical Systems 2 07-24-2011 04:24 PM
4 solar panels - series, parallel or series-parallel ArgleBargle Gear & Maintenance 1 04-26-2011 08:27 AM
parallel sails? jbarros Sailboat Design and Construction 23 05-28-2010 10:20 PM
