Sailing dinghy w/o headsail - Page 2 - SailNet Community
post #11 of 16 Old 11-13-2012
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Sailing dinghy w/o headsail
Yer talkin' a dink here.. notta Endeavor 39!
Go to local Ace hardware or equiv. Find the pulley aisle. Pick up a brass/bronze and alloy or better yer, chrome plated block. Attach as needed and run line. Go sailing!
If it wears out or suffers corrosion, replace it for $2.49
deltaten is offline
post #12 of 16 Old 11-13-2012
I,m assuming the jib luff is tensioned with some kind of highfield lever. In that case, yes the ideal is to have a dyneema "jib replacement" line, as you can't get the forestay tight enough. The forestay really just keeps the mast up while you're changing jibs. This is how my wayfarer was rigged, until I installed roller furling.
MarkSF is offline
post #13 of 16 Old 11-27-2012
Originally Posted by FlyingJunior View Post
Ok, rigged boat up in the driveway today. I just wrapped the jib around the forestay, and secured it with a sail tie - easy! Also, I tied a loop into the jib halyard about 2 feet above where it gets cleated off when the jib is raised. With this loop, I can get more leverage on the halyard so that the luff is as tight as it can be - voila! I know there's a way to incorporate a block system for this purpose, but I'm not sure how to do that.
that is how I do it on my Snipe. I am a novice and tacking seems to work ok with only the main. I have started to single hand in light winds with both flying. I am sure to keep my feet under the hiking straps for puffs and have the jib sheet over my knee in in my lap.
With the jib rolled up if you decide to let it fly all you have to do is unfurl it while heading into the wind.
handsomebob is offline
post #14 of 16 Old 12-02-2012
FJ,
single handed today in 5-10 mph with a few gust a little more in my Snipe. With main and jib you will have more control. No need to use main only: you will just look like a puss. Just use the main to spill if you start to feel uncomfortable. No big deal tacking under both. Just have you main set and work the jib over to the other side and you will be set.
post #15 of 16 Old 12-03-2012 Thread Starter
thanks, @handsomebob - I agree that tacking single-handed isn't a big deal, as the main is pretty well taken care of. Jibing gets a bit more complicated.
thanks also @deltaten, you're right, it's just a dink. I like the pulley idea. I saved myself the paltry 2.49 with my loop tied in my halyard!
The other thing about my low hanging boom, is that it's imperative the head of the mainsail is all the way to the top. In my experience, a bowline often has too much length of knot, and doesn't allow the head to get all the way up, thus resulting in a lower boom. Many shackles are also 3" or so long and result in the same issue. It seems it's blasphemy, but I've found that a round-turn-and-two-hitches works the best here, to raise the mail as high as it can go. A very secure knot and still easy to untie. Again, this is a dink, but let's not introduce bad habits, huh?
FlyingJunior is offline
post #16 of 16 Old 12-03-2012 Thread Starter
Originally Posted by handsomebob View Post
FJ,
I agree, 5-10 is very comfortable for me where I am in my sailing right now, and these little boats move along just fine with this amount of wind. When winds get to 18+ it gets a little more hairy. My experience sailing cat-rigged boats is more extensive, regarding spilling the main (only) sail. Question, in a sloop, would spilling the jib offer just about as much relief, or because the jib is so much smaller than the mainsail, it would not? I was always taught (on keelboats) that the headsail is the power.
Thanks,
FJ
Sailing dinghy nelsonsmoody Boat Review and Purchase Forum 4 03-12-2013 07:57 AM
Youth sailing: National dinghy sailing championship off Marco's shores NewsReader News Feeds 0 10-06-2011 11:20 PM
Dinghy Sailing rjcaudle Learning to Sail 13 06-22-2011 09:37 PM
converting a furling headsail to a hanked on headsail mrkeith Gear & Maintenance 6 02-15-2007 02:36 PM
Spain. Trofeo SAR Princesa Sofía: Natalia Via-Dufresne to combine dinghy sailing & cruiser events @ BYM Sailing News NewsReader News Feeds 0 04-11-2006 11:15 PM
