Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #1
Old 10-04-2012
FlyingJunior is on a distinguished road
Sailing dinghy w/o headsail
For those that might not be aware, most dinghies ( like my FJ) have a wire luff in the headsail that functions as the forestay when the sail is raised. Anyone have any thoughts what I should use in its place if I want to sail with just mainsail alone? Was thinking 3/16" dyneema. One cannot just depend on the forestay, as you can't really get it tight enough, and I don't want to wrap the headsail around its luff wire (messy).
  #2
Old 10-04-2012
I should mention, "tight enough" regarding the forestay is important on these boats, as otherwise the boom rides too low to really sail it easily (mast rakes aft naturally or from weight of the boom). I guess I could rig a turnbuckle to the existing forestay (?).
  #3
Old 10-04-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Re: Sailing dinghy w/o headsail
A high tech, low stretch line like Dyneema or Amsteel sounds like the way to go to me.
Marine Amsteel on Sale
If you can rig a block to where you attach the jib or at the top of the mast you might even get some mechanical advantage for tightening your substitute fore stay - if you have a cleat to put the new line through.
I was going to say that some aft rake in the mast can be a good thing but too much rake such that you are bonking your head on the boom is not.
Everybody has one:
  #4
Old 10-04-2012
Sic Semper Tyrannis is on a distinguished road
Just run the existing halyard to the tack and tension. Should be fine.
Ric
Sent from my Kindle Fire
  #5
Old 10-04-2012
overbored's Avatar
overbored is on a distinguished road
not sure why your forestay is not tight enough to sail without the jib. we do it all the time when teaching with a cat rig. the forestay and shrouds should be slightly tight when the rig is up before the sails are hoisted. The forestay on the FJ is a set length and the shrouds have adjusters. the rig should be set to have a little tension on it when not sailing.
Rig a CFJ - YouTube" target="_blank">How to Rig a CFJ - YouTube
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #6
Old 10-04-2012
@Sic - to the tack attachment point at the bow? Makes sense, I may need a longer halyard .
  #7
Old 10-04-2012
@overbored - I raise the mast, attach forestay tightly using shroud adjuster. Once the boom with mainsail are rigged, boom rides too low to sail, without using headsail. Don't know what else to say.
  #8
Old 10-04-2012
overbored's Avatar
it should no be that low, check the forestay length. someone may have changed it with the wrong length.
  #9
Old 10-05-2012
I guess I'm failing to understand why it's tight, and then not. I thought from talking to others that this was the norm. Thank you for being patient with me and for your trouble, however. Maybe I will just wrap the headsail around its luff wire, and secure with sail ties.
  #10
Old 10-07-2012
Ok, rigged boat up in the driveway today. I just wrapped the jib around the forestay, and secured it with a sail tie - easy! Also, I tied a loop into the jib halyard about 2 feet above where it gets cleated off when the jib is raised. With this loop, I can get more leverage on the halyard so that the luff is as tight as it can be - voila! I know there's a way to incorporate a block system for this purpose, but I'm not sure how to do that.
You may post attachments
You may edit your posts
Sailing dinghy nelsonsmoody Boat Review and Purchase Forum 4 03-12-2013 07:57 AM
Youth sailing: National dinghy sailing championship off Marco's shores NewsReader News Feeds 0 10-06-2011 11:20 PM
Dinghy Sailing rjcaudle Learning to Sail 13 06-22-2011 09:37 PM
converting a furling headsail to a hanked on headsail mrkeith Gear & Maintenance 6 02-15-2007 02:36 PM
Spain. Trofeo SAR Princesa Sofía: Natalia Via-Dufresne to combine dinghy sailing & cruiser events @ BYM Sailing News NewsReader News Feeds 0 04-11-2006 11:15 PM
SEO by vBSEO 3.6.1
