Course to steer at a given speed. - Page 2 - SailNet Community
 3Likes
post #11 of 18 Old 12-06-2012
jackdale's Avatar
Re: Course to steer at a given speed.
Originally Posted by jrd22 View Post
Sailing isn't straight line, or constant speed. Your course will vary based on wind direction, speed through the water, etc so while your question is a good mental exercise it's not a practical application for sailing. In other words, line up the bearing line on your chartplotter with your destination and do your best to get there as soon as possible:-))
It is a fairly standard part of coastal navigation courses.
Your use of a bearing line will result in a curved course.
A example is crossing Georgia Strait from Vancouver to Silva Bay. On a strong ebb if you wish to minimize the time on course you will have to point further north than the bearing found on your chartplotter. If you simply use the bearing and maintain it you will up down by Thrasher Rock.
Of course, this is predicated on the ability to point.
jackdale is offline
post #12 of 18 Old 12-06-2012
Courtney the Dancer
jrd22's Avatar
sv+ jack- note the smiley at the end? Tongue in cheek response to the OP's question about a straight line solution to his question. I too have been getting where I'm going for 40 years. Here in the PNW it's not uncommon to be crabbing 40-50 degrees one way and then the other a few minutes later while trying to maintain a course.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #13 of 18 Old 12-06-2012
Courtney the Dancer
jrd22's Avatar
Actually, if you use the bearing line on your chartplotter and change your heading to compensate for leeway, current, etc in order to keep the line on the destination you will travel a straight course to the destination. In your example Jack, if the current is ebbing in Georgia in order for the bearing line to be pointed at Silva B you will have to be pointing further and further N as you get into the main current and then less as you get out of the current as you approach destination. The bearing line gives you your direction traveled over the ground so it adjusts your heading if you keep the line on the destination. I do it all the time crossing Rosario in the power boat and end up with an arrow straight line regardless of the varying currents.
John
SV Laurie Anne
jrd22 is offline
post #14 of 18 Old 12-06-2012
chucklesR's Avatar
Jack, JRD etc..
Or of course, not to point (so well).
I add 3-5 degrees of lee way as an assumption when I'm laying base course lines.
Absolutely correct - but, assuming the OP doesn't have a chartplotter and a autopilot to follow it, the exercise is a good one - to determine an approximate course to get one near his destination.
That curved course line looks a lot more like a snake every time I look at my wake.
chucklesR is offline
post #15 of 18 Old 12-06-2012 Thread Starter
First, I'd like to say thanks for all of the responses. You guys have really given insight to someone who doesn't spend much (if any) time on the water. (Marine nav. is just a hobby of mine.)
Second, a big thanks to svHyLyte. Your explanation of Polars is exactly what I was missing.
Originally Posted by svHyLyte View Post
In terms of your question seeking a specific time of arrival...
Sorry, I should've clarified this part a bit. It was a problem about keeping a schedule that got me thinking, but my question here was not ultimately about that. It was mainly about staying on course with a variable speed, such as in a sailboat. And as I said, you have resolved that problem for me.
Thanks, again!
-Sean
seanpatrick is offline
post #16 of 18 Old 12-06-2012
jackdale's Avatar
One way to do the calculations
https://www.youtube.com/watch?v=7ahoGVGA1do
chucklesR likes this.
jackdale is offline
post #17 of 18 Old 12-07-2012
chucklesR's Avatar
he said the magic word 'leeway'
What he didn't say was "oops, I can't steer that high, so I fell off 3 degrees, then had to tack 3 miles to starboard' because the on shore wind shifted.
jackdale likes this.
post #18 of 18 Old 12-07-2012
jackdale's Avatar
Actually it can work the other way. In 2007 Van Isle 360, when we were coming back from about 55 miles offshore, we got this great lift that took us to within about three miles of the leg finish. Then the wind died - offshore breeze competing with the prevailing westerlies.
jackdale is offline
Bum Steer - rudder gland question skipgundlach Gear & Maintenance 1 03-09-2012 10:46 PM
Windvane self steer CRN1857 Gear & Maintenance 8 08-04-2010 01:02 PM
Why does boat steer to hard starboard? funsailthekeys Gear & Maintenance 14 09-08-2008 01:50 AM
Steer with rudder or outboard? eMKay Learning to Sail 19 06-05-2008 07:33 PM
How to Steer in Waves Carol Cronin Racing Articles 0 06-10-2002 08:00 PM
