Heavy winds? - Page 2 - SailNet Community
 8Likes
post #11 of 35 Old 12-15-2012
Re: Heavy winds?
The point was that indeed, the 'force' from a given windspeed can be noticeably stronger in cold air than warm.
Faster agree 100%, was not disputing...actually relieved
as now i have some theory as to why the equivalent winter
wind seemed so much more intimidating then in summer!
HUGOSALT is offline
post #12 of 35 Old 12-15-2012
Re: Heavy winds?
Yes. Air is denser when it is colder. But it is denser on both sides of the sail, and it is the pressure difference that creates the force.
Doug
Desiderata
Oceanus 393
dugsmith98 is offline
post #13 of 35 Old 12-15-2012
sunfish?junior?
Re: Heavy winds?
check pressure density altitude and the temp relationship and the lift you get under the wing? Is a sail a wing on its side? Yes you are at the same alt unless the lake level is lower but small drops will not mean much. Alt may only come into play if you sail a lake at high alt vs ocean sea level Regards , Lou
Lou452 is offline
post #14 of 35 Old 12-15-2012
Moderator
Jeff_H's Avatar
Re: Heavy winds?
As other have said, the cooler drier air of winter is noticably denser than the warmer damper air of summer. So a cooler wind of any given velocity will definitely result in more force on your sails than the same velocity breeze in summer. This is most notable during a winter sail when a small numerical windspeed change results in a much bigger apparent wind shift and more heeling. Sails that I can carry in summer into the mid-20 knot range, barely make it to 20 knots in winter.
Jeff_H is online now
post #15 of 35 Old 12-15-2012
blt2ski's Avatar
Re: Heavy winds?
A few years ago on new years, sons and I went out sailing in about 15 knots, put up the 135 I had at the time as we did in the summer, needed a reef pretty dang quick! So yes as others have said, winter colder temps one does not need as much SA up to hit the same speed, heeling etc. I'm 3-5 knots of wind slower in the winter vs summer temps, ie over 60 vs under say 50-60. Closer to freezing, even less yet.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #16 of 35 Old 12-15-2012
Re: Heavy winds?
Imagine extremes to make the comparison between light and heavy air understandable. First think of a sail in space. Space is not 100% empty, it has just very, very little particles. Probably you are not gonna see anything hapening to your sail if these particles are moving at 12 knots? Now imagine using a sail in water with a 12 knot current. Water here represents very very heavy air. Probably your sail rips to pieces pretty soon.
So i dont know for certain how to explain scientifically why i think your airpressure difference thingy is wrong, but it really seems wrong to me
Arjen is offline
post #17 of 35 Old 12-15-2012
Re: Heavy winds?
Btw, i am pretty new to sailing and have a question:
-How do you decide when you need to reef your sail, where is the limit ?
I have just recently gotten myself a boat and have sailed it from guatemala to cozumel this far. On the road i got into some pretty winds a few times. The first time as i was going sharp into the wind, it got really strong, it scared me and i took the sail down just(didnt yet know how to reef so took it down completely) Probably the boat bouncing like an idiot, sprays of water reaching into the cockpit and me getting seasick helped create my fear more than any objective observations.
A few days later i had a wonderfull SE wind when going from san pedro, belize to cozumel on a beam reach. I made 8,5 knots while my hullspeed is 7 knots. I figured that must be ok because there is supposed to be a 2 knot current helping me and i kept the sails up. But stil l must admit i hade some slight doubts if this was being a good thing for my boat and sails. So where should i draw the line ?
Arjen is offline
post #18 of 35 Old 12-15-2012
pdqaltair's Avatar
Re: Heavy winds?
The thread is off the point. The OP judged the wind speed only by sea state. He did not measure true wind speed.
OBVIOUSLY cold air is more dense. Airplanes in the desert commonly take off lighter because they don't have the lift. But the point is if you measure the wind speed by its effect on the sea state, that has already been taken into account. It will push the waves in the same manner it will push your boat.
Simple, no aerodynamic hand waving required.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #19 of 35 Old 12-17-2012
Barquito
Barquito's Avatar
Re: Heavy winds?
True. That, and climate change...
Just kidding. I agree with the science. It is enlightening to hear some that have actually been able to percieve the difference. If I was guessing, I would have assumed that small differences in wind velocity would have a much larger impact than air density. Good to learn new things!
Valiant 32
Barquito is offline
post #20 of 35 Old 12-17-2012
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Heavy winds?
So basically, if i am sailing downwind and am drinking an ice cold beer, the wind blowing over it to my sails, my boat will go faster? Yet another reason to drink ice cold beer. Thank you Faster. Btw, if I put a fan behind my beer, will I go even faster (no pun intended Faster).
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
Tacking in heavy winds Jetexas Learning to Sail 8 12-18-2012 03:17 PM
Heavy winds take a toll in New Bedford harbor - SouthCoastToday.com NewsReader News Feeds 0 11-09-2012 11:40 PM
Where I've Been (Pic Heavy) Cruisingdad General Discussion (sailing related) 16 11-06-2011 08:07 PM
Sailors faced heavy winds at Dauphin Island Race (Pensacola News Journal) NewsReader News Feeds 0 05-02-2006 02:16 AM
Good for heavy AND light winds? jbarros Boat Review and Purchase Forum 4 09-30-2003 11:03 AM
