speed question - SailNet Community
Advertise Here
Go Back   SailNet Community > Skills and Seamanship > Learning to Sail
Old 04-06-2004
thalassolikos is on a distinguished road
speed question
what is the max sailing speed of something like a cal 34?
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 04-06-2004
928frenzy is on a distinguished road
speed question
For displacement hulls, the formula is:
Boat speed (in knots) = 1.34 x (the square root of the boat''s waterline length [in feet]).
For a boat with a waterline length of exactly 25'', the speed would be 1.34 x 5, which is 6.7 knots. The speed for a boat with a 36'' waterline would be 1.34 x 6 = 8.04 knots.
I guess the Cal 34 has a waterline of about 28'', so its speed should be about 7 knots.
~ Happy sails to you ~ _/) ~
  #3
Old 04-06-2004
Jeff_H's Avatar
Moderator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
speed question
That is not an easy question to answer. Surfing a boat like a Cal 34 might hit 9-10 knots of even higher for a few seconds. That would be thier maximum speed. The previous answer addressed hull speed which is a theoretical limit on speed in the absense of of wave action (roughly 1.33 times the square root of the waterline length). That is really not very accurate number as a predictor of how fast any individual boat might actually be. Modern boats tend to easily exceed their hull speed while older designs tend to spend a substantial portion of time well below their hull speeds.
You may post attachments
You may edit your posts
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 05:14 PM
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-21-2006 11:58 PM
''84 Evinrude 9.9 spark question BrianConley Gear & Maintenance 0 08-05-2001 07:51 PM
ideal wind speed? brucemcald Learning to Sail 9 07-21-2001 05:30 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
